Hi
I know this works outside of Revit can't get to work when called.
code
If System.IO.File.Exists("filename.txt") = True Then
'open file and read contents
objWordReader = System.IO.File.OpenText("filename.txt")
Do Until objWordReader.Peek = -1
wordlevel = objWordReader.ReadLine()
If wordlevel.StartsWith("x") = True Then
wordremove = wordlevel.Remove(0, 17)
intword = wordremove.IndexOf(",")
wordremoveII = wordremove.Remove(0, intword + 1)
NewWord = wordremoveII.Substring(0, 5)
TextBox1.Text = NewWord
Loop
objWordReader.Close()
bob v
