.NET
Read entities of a blockreference
5 REPLIES 5
fantarama
477 Views, 5 Replies
I have a block that is defined by two other blocks and i need to read the attributes inside them, how can i do? i can read the main blockreference but then?
Second problem: after a selecion using Editor.GetSelection the command line don't came back to Command: status, but it seem that the command is already active and all other functions are stopped (es. it doesn't raise the editor's events)
5 REPLIES 5
foruma000256
in reply to: fantarama
problem 1, This is how you process a block to insert attributes after the block has been inserted. The GetEnumerator is the method to see entities inside of a block. Then you just need to find the blockreference inside this block and get to its block table record, then get its enumerator, as deep as you can get. I put the attribute code in here so you can see how it is created/accessed.
btrenum = btr.GetEnumerator
While btrenum.MoveNext
ent = btrenum.Current.GetObject(OpenMode.ForWrite)
If TypeOf ent Is AttributeDefinition Then
Dim attdef As AttributeDefinition = ent
Dim attref As New AttributeReference
attref.SetAttributeFromBlock(attdef, br.BlockTransform)
attref.TextString = attdef.TextString
attColl.AppendAttribute(attref)
trans.AddNewlyCreatedDBObject(attref, True)
End While
Problem 2. Dunno much, I just add ed.WriteMessage "Command: " to clean up the command line later. A vbcr should work too. Or is your problem with the user not escaping out of the getselection command?
Not sure why you using GetEnumerator(), MoveNext(), and Current (saw it in Reflector's disassembly perhaps?), but you don't use that.
You just use 'For Each', which compiles to the same thing.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2009
Supporting AutoCAD 2000 through 2009
http://www.acadxtabs.com
Introducing AcadXTabs 2010:
http://www.caddzone.com/acadxtabs/AcadXTabs2010.htm
wrote in message news:5981606@discussion.autodesk.com...
End While
foruma000256
Our friend Jerry W. said so... Although I would much rather use for each if it works. So, where is your book on the subject, I'm sure it would be a best seller. :~)
fantarama
Thank you for prob#1, for #2 the user select the object, i do what i need with picked pbject but after that the command line don't show the Command: message but the message i've set to the promptoption object. I've added vbcr but it just append blank line!!
foruma000256
Yea, then use the:
ed.writemessage (vbcr & "Command: ")
to clean it up.
”Boost
