.NET
Read dwg extents
9 REPLIES 9
Message 1 of 10
659 Views, 9 Replies
Read dwg extents
Hi!
I would like to make windows service (.NET C#), which would watch directory changes and read dwg extents, if file extension was .dwg.
Is this possible to make on machine, where autocad isn't installed?
9 REPLIES 9
Message 2 of 10
arcticad
You would have to use RealDWG or OpenDesign
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=770257
http://www.opendesign.com/
(defun botsbuildbots() (botsbuildbots))
Message 3 of 10
in reply to: arcticad
Is there no free alternative?
Message 4 of 10
dgorsman
Could you elaborate on the reasoning behind this?  There may be "in drawing" solutions that could fulfull the requirements.
Message 5 of 10
I am working on application, which creates database with information of extents of DWG, TIF and other geolocated files.
Then user can click on some location on the map and check which files are under that location.
I solved all other formats, but not dwg. I can read DWG extents only inside autocad.
If there is no free solution to do this without AutoCAD, is this possible on machine that has AutoCAD installed without running autocad?
Thank you in advance!
Message 6 of 10
arcticad
If you don't want to pay for a solution then you will have to create an instance of AutoCAD to be able to run your code,
Message 7 of 10
fieldguy
Yes.  You can search here for "out of process" or "unmanaged".  There should be several examples.  What version of acad are you targeting?
Message 8 of 10
arcticad
I'd like to know what your referring to...
You will still have to connect to AutoCAD to run your application via ActiveX API and create an instance of AutoCAD.
You don't need to show autocad on the screen but it's still running.
Message 9 of 10
fieldguy
in reply to: fieldguy
Scratch that - sorry.  I was taking out-ot-process too literally.
Message 10 of 10
adadnet
hi borut
autodesk publish dxf code references as pdf file by autocad version here:
http://usa.autodesk.com/adsk/servlet/item?linkID=10809853&id=12272454&siteID=123112
it's introduction says that "The DXFformat is a tagged data representation of all the information contained in an AutoCAD® drawing file. Tagged data means that each data element in the file is preceded by an integer number that is called a group code."
so therefore i think that once you have a .dwg file saved as a .dxf file, you could write a .net application that searches this .dxf file for respective group codes and associated values; e.g. the dxf 'header variables' for drawing extents are given on p19 (i.e. from the acad2011 ref). unfortunately, i haven't done this myself, but .dxf files can be used by non-acad software.
felix
”Boost
