.NET
Read all entity in Block definition
2 REPLIES 2
260 Views, 2 Replies
Is already too much time that i search the way to iterate in Block
definition to read the objectid of any entity contained.
Someone can explain me the correct way to make it?
I want use the dotnet managed library not Com ,because with com i know the
system.
Many thank's in Advance
GPaolo
2 REPLIES 2
As variant:
[code]
static public ObjectIdCollection GetAllObjectIdsInBlockDef(ObjectId idBlockDef)
ObjectIdCollection ids = new ObjectIdCollection();
Database db = idBlockDef.Database;
Transaction trans = db.TransactionManager.StartTransaction();
try
BlockTableRecord btr = (BlockTableRecord)(trans.GetObject(idBlockDef, OpenMode.ForRead));
foreach (ObjectId id in btr) ids.Add(id);
trans.Commit();
finally
trans.Dispose();
return ids;
[/code]
Only for testing:
[code]
[CommandMethod("GetAllIdsInCurrentSpace")]
static public void GetAllIdsInCurrentSpace()
Autodesk.AutoCAD.EditorInput.Editor ed =
Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor;
Database db = HostApplicationServices.WorkingDatabase;
ObjectIdCollection ids = GetAllObjectIdsInBlockDef(db.CurrentSpaceId);
ed.WriteMessage("\nNumber of entities in current space: {0}",ids.Count);
[/code]
ok.Many thanks
ha scritto nel messaggio
news:5158998@discussion.autodesk.com...
As variant:
[code]
idBlockDef)
try
OpenMode.ForRead));
trans.Commit();
finally
trans.Dispose();
return ids;
[/code]
Only for testing:
[code]
cument.Editor;
[/code]
”Boost
