.NET
RBG value from color dialog
12 REPLIES 12
Message 1 of 13
1108 Views, 12 Replies
Can someone point me in the right direction for pulling the RGB value from the color dialog and pass them on to a windows form background color?
12 REPLIES 12
Message 2 of 13
ahmed.felix
I'm not sure if I get your question right but maybe it's this:
Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
Dim dlgColor As New ColorDialog
dlgColor.ShowDialog()
Me.BackColor = dlgColor.Color
End Sub
This passes the color value to the form that loads at startup. If you need it in another form just instantiate it: formX=new Form and set the color to it.
Message 3 of 13
Littlerubarb
Not exactly, Here's what I'm trying to do.
I have a color swatch on a user form that needs to change color when the user picks a color from the AutoCAD color dialog. The problem I've ran into is that AutoCAD uses it own color system ACI and I need to convert this to RGB for the color swatch. I could do it by creating a spread sheet with all 256 ACI Color number and RGB reference but I was hoping their is a easier way.
Message 4 of 13
saluki
This may help you out . . .
http://discussion.autodesk.com/thread.jspa?messageID=414913
Message 5 of 13
cgay
There is a type defined, Autodesk.AutoCAD.Colors.
This type has some shared methods, like 'FromColorIndex(colorMethod,colorIndex)' where color method is the enum type ColorMethod which defines among others 'ByAci', and colorIndex is of numerical type Short.
This method returns a Autodesk.AutoCAD.Color object.
The Autodesk.AutoCAD.Color type defines Red,Blue,Green as byte.
Message 6 of 13
Mikko
You need to pull the RGB values from the color.
MsgBox(dlgColor.Color.ColorValue.R.ToString & ", " & dlgColor.Color.ColorValue.G.ToString & ", " & dlgColor.Color.ColorValue.B.ToString)
Message 7 of 13
Here's what I've tried, this returns The ACI...
I've tried all these solutions to no return...Thanks for The table one less thing if I'm forced to use it
Now if I set Autodesk.AutoCAD.Colors.Color.FromRGB it return random colors..
Public Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
Dim CD As New Autodesk.AutoCAD.Windows.ColorDialog()
Dim C As Autodesk.AutoCAD.Colors.Color = Autodesk.AutoCAD.Colors.Color.FromColorIndex(Autodesk.AutoCAD.Colors.ColorMethod.ByAci, 1) 'Set color to RED
Dim PENN As Object
CD.Color = C
CD.SetDialogTabs(Autodesk.AutoCAD.Windows.ColorDialog.ColorTabs.ACITab Xor Autodesk.AutoCAD.Windows.ColorDialog.ColorTabs.ColorBookTab)
If CD.ShowDialog <> Windows.Forms.DialogResult.OK Then
PENN = CD.Color.ToString
TextBox2.Text = PENN
End Sub
Message 8 of 13
Just to Clarify
When I approached this I though ha just set r to string ... and so on..
Boy was i wrong it keeps on returning random colors and numbers.. Give it a try
Message 9 of 13
cgay
This works.....
CD.Color = Autodesk.AutoCAD.Colors.Color.FromColorIndex(Autodesk.AutoCAD.Colors.ColorMethod.ByAci, 1)
CD.SetDialogTabs(Autodesk.AutoCAD.Windows.ColorDialog.ColorTabs.ACITab)
Dim dr As DialogResult = CD.ShowDialog
If dr = DialogResult.OK Then
MsgBox(CD.Color.ColorValue.ToString, MsgBoxStyle.OkOnly, "ColorInfo")
End Sub
note on : CD.Color.ColorValue
ColorValue is a system.drawing.color type and can be used directly in coltrols and such
Message 10 of 13
Thanks, that what I was missing...
I'll repost the code in a minute..
Message 11 of 13
I got it to work this is the code I ended up using for now..
Dim PENN As Object
Dim r As Integer
Dim g As Integer
Dim b As Integer
CD.Color = C
r = CD.Color.ColorValue.R.ToString
g = CD.Color.ColorValue.G.ToString
b = CD.Color.ColorValue.B.ToString
PictureBox1.BackColor = System.Drawing.Color.FromArgb(r, g, b)
I tried combiing the RGB value and couldn't get it to work do you see anything that's missing
Dim swatch As String
swatch = CD.Color.ColorValue.R.ToString + "," + CD.Color.ColorValue.G.ToString + "," + CD.Color.ColorValue.B.ToString
PictureBox1.BackColor = System.Drawing.Color.FromArgb(swatch) Message was edited by: Littlerubarbwk
Message 12 of 13
cgay
You can use CD.Color.ColorValue directly as a system.color
like so:
CD.Color = Autodesk.AutoCAD.Colors.Color.FromColorIndex(Autodesk.AutoCAD.Colors.ColorMetho d.ByAci, 1) 'Set Color to Red
Dim dr As DialogResult = CD.ShowDialog 'Show the Dialog
If dr = DialogResult.OK Then 'If user clicked OK then
PictureBox1.BackColor = CD.Color.ColorValue 'Set the backcolor to the color selected
End Sub
Message 13 of 13
Thanks it works
”Boost
