.NET
RasterImages
6 REPLIES 6
546 Views, 6 Replies
RasterImages
I think I'm going about this the wrong way.
I want to rename the RasterImage Files to Match the Drawing Naming Convention Plus a Suffix.
In this case _A, _B, _C etc.
And update that in the Drawing.
 Public Shared Sub RenameRasterImagesAndReattachToDrawing(ByVal FilePath As String)
        Dim sNewName As String = ""
        Dim iImg As Integer = 0
        Dim Suffix As String = "A"
        Dim myDwgIO As New IO.FileInfo(FilePath) 'Get FileName from Full FilePath
        '<<<1. Locate Raster Images
        'Autocad Database Adapter
        'Read Autocad File Silently without opening file on Screen
        Dim myDoc As Autodesk.AutoCAD.ApplicationServices.Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
        'Start(Transaction)
        Using myTrans As Autodesk.AutoCAD.DatabaseServices.Transaction = myDoc.Database.TransactionManager.StartTransaction
            '~~~~~~~~~~~~~~~~~~~~~~~~TEMP CODE~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
            'Take a Look at Attachments
            'Open The Dictionary
            Dim nod As Autodesk.AutoCAD.DatabaseServices.DBDictionary
            Dim imageDict As Autodesk.AutoCAD.DatabaseServices.DBDictionary
            nod = CType(myTrans.GetObject(myDoc.Database.NamedObjectsDictionaryId, Autodesk.AutoCAD.DatabaseServices.OpenMode.ForWrite, False),  _
                        Autodesk.AutoCAD.DatabaseServices.DBDictionary)
            imageDict = CType(myTrans.GetObject(nod.GetAt("ACAD_IMAGE_DICT"), _
            For Each dicentry As Autodesk.AutoCAD.DatabaseServices.DBDictionaryEntry In imageDict
                Dim myRasterImgDef As Autodesk.AutoCAD.DatabaseServices.RasterImageDef = _
                CType(myTrans.GetObject(CType(dicentry.Value, Autodesk.AutoCAD.DatabaseServices.ObjectId), _
                                         Autodesk.AutoCAD.DatabaseServices.OpenMode.ForWrite),  _
                                          Autodesk.AutoCAD.DatabaseServices.RasterImageDef)
                '<<<2. Save Information to Memory Object
                Dim TempString As String = myRasterImgDef.Handle.ToString
                'MsgBox(TempString)
                '<<<3. Rename Files (Enforce Naming Convention)
                Try
                    Dim sFileFullName As String = myRasterImgDef.SourceFileName
                    'Get File Directory
                    Dim myFileIO As System.IO.FileInfo
                    myFileIO = My.Computer.FileSystem.GetFileInfo(sFileFullName)
                    'FileName
                    Dim sFileName As String = myFileIO.Name.Substring(0, (myFileIO.Name.Length - 4))
                    'Store NewName in Memory Object
                    sNewName = myFileIO.Directory.ToString & "\" & sFileName & "_" & Suffix & ".dwg"
                    MsgBox(sNewName)
                    'Rename File
                    If Not My.Computer.FileSystem.FileExists(sNewName) Then
                        My.Computer.FileSystem.CopyFile(sFileFullName, sNewName)
                    End If
                    'Increment Letter
                    Suffix = GetNextLetter(Suffix)
                    '<<<4. Confirm Renames??
                Catch ex As Exception
                    MsgBox(ex.Message)
                End Try
                myRasterImgDef.SourceFileName = sNewName
                myRasterImgDef.ActiveFileName = sNewName
                MsgBox(myRasterImgDef.ActiveFileName & vbCrLf & myRasterImgDef.SourceFileName)
            Next
            'Commit Transaction
            myTrans.Commit()
        End Using
    End Sub
6 REPLIES 6
fieldguy
You are further along with raster images than I have gotten.  I would try to detach the old and attach the new if renaming does not work.
in reply to: fieldguy
Thanks, I'll give it a shot.
Dale.Bartlett
I'm trying to do that at the moment: find and detach all images in the drawing. Seems to be trickier than it sounds, or I am half asleep... Dale
______________
Yes, I'm Satoshi.
Yah it is tricky,
Haven't figured it out yet...
But let me know if you have any luck... Or if I get around to it again I'll post my code.
Dale.Bartlett
Glad to know I'm not alone. I'd post some sample code but I've gone down so many rabbit holes it's shameful. I'll keep note of this page and post a solution when I get it resolved. Simply I want to detach all images in a drawing; trivial in Lisp. Regards, Dale
______________
Yes, I'm Satoshi.
Following code deletes all raster images in a drawing. It seems to work well, but I'm open to improvements or comment. Regards, Dale
<code>
[CommandMethod("RXC")]
        public static void RasterRemoveAll()
            Document doc = AcadApp.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            Database db = doc.Database;
            // store drawing name for error report
            string lstrDWGFileName = db.Filename.ToString();
            using(Transaction tr = db.TransactionManager.StartTransaction())
                try
                    // Tanzillo:
                    // To get your code to work in 2009, do this before you create any RasterImageDef objects:
                    RasterImage image = new RasterImage();
                    image.Dispose();
                    // These two lines of code will force the managed runtime to load the RasterImage .DBX module.
                    // who knows if needed now?
                    // open The  Named Object Dictionary
                    DBDictionary nod = tr.GetObject(db.NamedObjectsDictionaryId, OpenMode.ForRead) as DBDictionary;
                    if(nod.Contains("ACAD_IMAGE_DICT") == false)
                        return;
                    // get the image definition dictionary id
                    ObjectId imageDictId = RasterImageDef.GetImageDictionary(db);
                    if(imageDictId == null)
                        return;
                    DBDictionary imageDict = tr.GetObject(imageDictId, OpenMode.ForRead) as DBDictionary;
                    if(imageDict.Count == 0)
                        return;
                    imageDict.UpgradeOpen();
                    // loop through all images
                    foreach(DBDictionaryEntry entry in imageDict)
                        // get the object ID of the image definition
                        imageDictId = entry.Value;
                            return;
                        // remove image definition from the dictionary
                        imageDict.Remove(imageDictId);
                        // delete image definition object
                        RasterImageDef imageDef = tr.GetObject(imageDictId, OpenMode.ForWrite) as RasterImageDef;
                        imageDef.Erase();
                    tr.Commit();
                catch(Autodesk.AutoCAD.Runtime.Exception ex)
                    MessageBox.Show(ATK_CommonLibrary.UtilityLibrary.ErrorMessage(ex, MethodBase.GetCurrentMethod().Name.ToString(), lstrDWGFileName), "Error Log");
<code>
______________
Yes, I'm Satoshi.
”Boost
