.NET
RasterImageDef
12 REPLIES 12
Message 1 of 13
SoloviewSerg
1382 Views, 12 Replies
RasterImageDef
i have Autodesk.AutoCAD.DatabaseServices.Image in Autodesk.AutoCAD.DatabaseServices.BlockTableRecord named *ModelSpace.
How convert It to Autodesk.AutoCAD.DatabaseServices.RasterImage ?
i have Autodesk.AutoCAD.DatabaseServices.DBObject in
Autodesk.AutoCAD.DatabaseServices.DBDictionary
named "ACAD_IMAGE_DICT"
How convert It to
Autodesk.AutoCAD.DatabaseServices.RasterImageDef ?
12 REPLIES 12
Message 2 of 13
in reply to: SoloviewSerg
What version of AutoCAD are you using. I seem to remember we had a bug in
R2005 so you really had to go out of you way to manipulate raster images. We
fixed this in R2006. If you are working witth R2005 then let me know and
I'll try to dig up the workaround (I seem to remember there was one...)
Albert
wrote in message news:4850136@discussion.autodesk.com...
How convert It to
Message 3 of 13
SoloviewSerg
For Albert Szilvasy .
Yes,I try to use R2005. I will be very grateful, if you fix my problem.
I work in VS2003EA,VB.net.
But what kind difference R2005 from R2006 ?
Thank You for answers.
Message 4 of 13
Here's some code that hopefully helps you out. There's a lot of difference
between R2005 and R2006 with regards to the .NET. We expanded the API quite
a bit.
Albert
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Runtime
Public Class Test
_
Public Sub Test()
Dim db As Database = HostApplicationServices.WorkingDatabase
Dim nod As DBDictionary
Dim imageDict As DBDictionary
Dim rasterImageDef As
Dim dictEntry As System.Collections.DictionaryEntry
Dim tm As Autodesk.AutoCAD.DatabaseServices.TransactionManager =
db.TransactionManager
Dim trans As Autodesk.AutoCAD.DatabaseServices.Transaction =
tm.StartTransaction
Try
nod = tm.GetObject(db.NamedObjectsDictionaryId,
OpenMode.ForRead, False)
imageDict = tm.GetObject(nod.GetAt("ACAD_IMAGE_DICT"),
For Each dictEntry In imageDict
Dim obj As DBObject
obj = tm.GetObject(dictEntry.Value(), OpenMode.ForWrite,
False)
'check if obj is a RasterImage def the hard way:
If
obj.GetRXClass.IsDerivedFrom(RXClass.GetClass(GetType(RasterImageDef))) Then
'create a RasterImageDef wrapper
rasterImageDef =
DisposableWrapper.Create(GetType(RasterImageDef), obj.UnmanagedObject,
False)
Dim imagePath As String
' see if the image path is right
imagePath = rasterImageDef.SourceFileName
If Not rasterImageDef.IsLoaded Then
' Test - Force a regen
'rasterImageDef.AssertWriteEnabled(True, True)
rasterImageDef.Load()
Next
trans.Commit()
Catch
'aborts (or causes a "rollback" of) the transaction
trans.Abort()
'CommandLinePrompts.Message("Oops!!" & vbCrLf)
Finally
If (Not trans Is Nothing) Then
trans.Dispose()
End Try
End Sub
End Class
wrote in message news:4851393@discussion.autodesk.com...
Message 5 of 13
SoloviewSerg
I'm very glad to see your code.
It's working!!!!!!!!
Thank's for your attention.
Respectfully yours.
serg
Message 6 of 13
SoloviewSerg
For Albert.
I have got Autodesk.AutoCAD.DatabaseServices.RasterImage from Autodesk.AutoCAD.DatabaseServices.Image (by your code),but can I get RasterImageDef from TransactionManager in R2005 ?
Dim rasterIm As RasterImage
If image.GetRXClass.IsDerivedFrom(RXClass.GetClass(GetType(RasterImage))) Then
'create a RasterImage wrapper
rasterIm = DisposableWrapper.Create(GetType(RasterImage), image.UnmanagedObject, False)
Dim rastImDef As RasterImageDef
rastImDef = CType(tm.GetObject(rasterIm.ImageDefId, OpenMode.ForRead, True), RasterImageDef)
Once again thank you.
serg
Message 7 of 13
Have you tried going through the same trick or manually creating the wrapper
for the RasterImageDef?
Albert
wrote in message news:4851453@discussion.autodesk.com...
For Albert.
If
rasterIm =
serg
Message 8 of 13
SoloviewSerg
I have got RasterImage through the same trick from Image ( Image from CurrentSpace), but I can't get RasterImageDef from : rasterIm.ImageDefId
rastImDef = tm.GetObject(rasterIm.ImageDefId,
Message 9 of 13
Ok. So once you have rasterIm.ImageDefId do this (I haven't compiled this so
please excuse any typos):
Dim obj As DBobject = tm.GetObject(rasterIm.ImageDefId, OpenMode.ForRead,
True)
If obj.GetRXClass.IsDerivedFrom(RXClass.GetClass(GetType(RasterImageDef)))
Then
rasterImageDef =
False)
wrote in message news:4854580@discussion.autodesk.com...
Message 10 of 13
SoloviewSerg
for Albert.
Big thank's for Your halp!
But now I nave new question.
How to determine the status of RasterImageDef - "Unreferenced" ?
How to get a entity which referenced by RasterImageDef ?
I bear in mind that if entity is erased signifies that status of RasterImageDef is "Unreferenced".
serg.
Message 11 of 13
can you please suggest how to create system.image from autoCAD 2006 object image ... so that i will be able to use it on the user form.
thanks and regards,
namrata
Message 12 of 13
SoloviewSerg
Simply solution...
You can use DwgThumbnail.ocx Control on the user form.
serg.
Message 13 of 13
thanks i'll try it out
regards,
namrata
”Boost
