.NET
Rasterimage.Associaterasterdef ?? what's the deal with this
9 REPLIES 9
Message 1 of 10
cbertschy
961 Views, 9 Replies
I currently have code working that will grab an image stored on a local drive, create the rasterimagedef dictionary entry, create the raster image object, and display the image in autocad. The program works but there is no reactor link to the image and this is apparent as the xref/image manager shows that the added image entry has no references in the drawing. The drawing does have the image working... but clearly something is not linked correctly. I would normally post my code but I amaffraid it will be a garbled mess like the garbage I have been wading through to find something helpful since the forum update.
My code is very similar in structure to the attached link I found which has the same issue as my code is having. In fact, everything I have found online appears to have this same problem.
http://www.objectarx.net/bbs/viewthread.php?tid=2500 &ex tra=page%3D1
I have been trying to fix this by implimenting the rasterimage.AssociateRasterDef and stuffing the parameter with the new rasterimagedef() entry (both before and after the dictionary entry and transaction) with no luck. The mgd help is very vague on this and mentions that a RasterImageDefReactor must be constructed. I am still learning the C# api and language, with no background in c++ arx. A small example of using the AssociateRasterDef correctly would be very helpful.
Chris Bertschy
Side note: I typically post with OE, but I used the RTF web format for this one. It appears that the only way to get a readable post is to use the web rtf box. Are the users of newsgroup readers being punished??
9 REPLIES 9
Message 2 of 10
in reply to: cbertschy
Your code isn't calling RasterImage.AssociateImageDef(), which
is
what creates the reactor and adds it to
the RasterImageDef.
AcadXTabs: MDI Document Tabs for AutoCAD 2009
Supporting AutoCAD 2000
through 2009
href="http://www.acadxtabs.com">http://www.acadxtabs.com
I
update.
class=jive-link-external
href="http://www.objectarx.net/bbs/viewthread.php?tid=2500&extra=page...
Chris
Bertschy
punished??
Message 3 of 10
That is correct.  When I code something
like:
ri.associaterasterdef(rid);
I get an error in autocad that tells me the entry
does not exist in the database.
I am guessing that it is looking for a reactor id
that does not exist or that the raster image def is not being handle
properly.  My question is really where in the code would I put the call to
ri.associaterasterdef(rasterimagedef).  I found a small tid bit that
mentioned setting up a reactionid but nothing on how to handle this.
Attached is my version.  It is a work in progress.  I am posting via
OE so I have no idea how this will look.
Thanks, Tony.
public
class
size=1>ACADutility
public
size=1>static
void
color=#191970 size=1>addimage
size=1>(
double
size=1>height
size=1>double
width,
Point3d p1,
size=1>Point3d p2
Document doc =
Application.
size=1>DocumentManager
size=1>MdiActiveDocument
Database db =
doc.
size=1>Database
Editor ed =
doc.
size=1>Editor
Transaction tr =
db.
size=1>TransactionManager
color=#191970 size=1>StartTransaction
size=1>();
DocumentLock doclock =
doc.
color=#191970 size=1>LockDocument
using
size=1>(
tr)
BlockTable bt =
BlockTable)
size=1>tr
size=1>GetObject
size=1>db
size=1>BlockTableId
size=1>OpenMode
size=1>ForRead
BlockTableRecord btr =
new
size=1>BlockTableRecord
btr = (
size=1>tr
size=1>GetObject
size=1>bt
size=1>ModelSpace
size=1>OpenMode
size=1>ForWrite
RasterImageDef rid =
new
size=1>RasterImageDef
ObjectId ImgDictID =
RasterImageDef
size=1>.
GetImageDictionary
color=#006400 size=1>(
db
size=1>);
if
size=1>(
ImgDictID
size=1>.
IsNull)
ImgDictID =
RasterImageDef
size=1>.
size=1>CreateImageDictionary
size=1>db
rid.
size=1>SourceFileName
color=#0000ff size=1>"c:\\temp\\gis-image-test.jpg"
size=1>;
rid.
size=1>ResolutionUnits
size=1>Unit
size=1>Foot
rid.
color=#191970 size=1>Load
rid.
color=#191970 size=1>OpenImage
rid.
color=#191970 size=1>UpdateEntities
DBDictionary imgdict
size=1>=(
DBDictionary
size=1>)
tr.
color=#191970 size=1>GetObject
size=1>(
ImgDictID,
OpenMode.
size=1>ForWrite
ObjectId rasterimdefid
size=1>;
rasterimdefid =
imgdict.
color=#191970 size=1>SetAt
color=#0000ff size=1>"image-SERVICE"
rid);
tr.
color=#191970 size=1>AddNewlyCreatedDBObject
size=1>(
rid,
true
size=1>);
RasterImage ri =
new
size=1>RasterImage
color=#008000 size=1>
RasterImageDef newimagedef
size=1>= (
RasterImageDef
size=1>)
tr.
size=1>(
rid.
size=1>ObjectId
size=1>OpenMode
size=1>ForWrite
);// this was my last ditch
effort to get a raster image def to work. stuffing
//the original rid object into the method this not
work so I attempted to get update object after the image dictionary
update.  Not that this should mattre but I can't
//get it to work  upgrade open was something
ignorant that I also tried.  I had the ri.imagedfid = rid.objectid
commented out but still did not work.  all the
//example on the web show only this method being
used to link the raster image to the dictionary definition.  this does not
work correctly.  It does work to make the added image
//use the imagedefinition but does not add the
neccesary reactor info to recognize that the imagedef has references in the
drawing
newimagedef.
color=#191970>UpgradeOpen
size=1>();
ri.ImageDefId
color=#006400>=
rid.ObjectId
color=#006400>;
ri.
color=#191970>AssociateRasterDef
color=#006400>(
newimagedef
size=1>);
ri.Visible
color=#006400>=
true
color=#006400>;
ri.Orientation
color=#006400>=
new
color=#191970>CoordinateSystem3d
color=#006400>(
p1, new
Vector3d
color=#006400>(
width,
color=#00008b>0
color=#00008b>0
), new
Vector3d
color=#006400>(
0
color=#006400>,
height,
color=#00008b>0
btr.
color=#191970>AppendEntity
color=#006400>(
ri
tr.
color=#191970>AddNewlyCreatedDBObject
color=#006400>(
ri,
color=#008b8b>true
color=#008000>
tr.
color=#191970>Commit
color=#008000>
doclock.
color=#191970>Dispose
size=1>();
which is
the RasterImageDef.
through 2009
I
forum update.
href="http://www.objectarx.net/bbs/viewthread.php?tid=2500&extra=...
Chris Bertschy
Message 4 of 10
You don't pass any reactor id to
AssociateRasterDef().
You pass what the name of that method implies
(the
RasterImageDef object, which may need to be open
and write-enabled).
That's all there is to it. You don't need to deal
with
any reactors.
through 2009
like:
to ri.associaterasterdef(rasterimagedef).  I found a small tid bit that
Thanks, Tony.
public
class
size=1>ACADutility
public
size=1>static
void
size=1>(
double
size=1>height
size=1>double
width,
Point3d p1,
size=1>Point3d p2
Document doc =
Application.
Database db =
doc.
size=1>Database
Editor ed =
doc.
size=1>Editor
Transaction tr =
db.
size=1>();
size=1>=
doc
size=1>.
LockDocument
color=#006400 size=1>();
using
size=1>(
tr)
BlockTable bt =
BlockTable)
size=1>tr
size=1>GetObject
size=1>db
size=1>BlockTableId
size=1>OpenMode
size=1>ForRead
size=1>=
new
btr = (
size=1>tr
size=1>GetObject
size=1>bt
size=1>ModelSpace
size=1>OpenMode
size=1>ForWrite
new
RasterImageDef
size=1>.
size=1>GetImageDictionary
size=1>db
if
size=1>(
ImgDictID
size=1>.
IsNull)
ImgDictID =
RasterImageDef
size=1>.
size=1>(
db);
rid.
size=1>;
rid.
size=1>Unit
size=1>Foot
rid.
rid.
rid.
size=1>();
size=1>=(
DBDictionary
size=1>)
tr
size=1>.
GetObject
ImgDictID
size=1>,
OpenMode
size=1>.
ForWrite);
size=1>;
rasterimdefid =
imgdict.
rid);
tr.
size=1>(
rid,
true
size=1>);
RasterImage ri =
new
size=1>RasterImage
size=1>= (
RasterImageDef
size=1>)
tr
size=1>.
GetObject
rid
size=1>.
ObjectId,
OpenMode.
size=1>ForWrite
not work so I attempted to get update object after the image dictionary
something ignorant that I also tried.  I had the ri.imagedfid =
rid.objectid commented out but still did not work.  all the
not work correctly.  It does work to make the added image
drawing
newimagedef.
size=1>();
ri.ImageDefId
color=#006400>=
rid.ObjectId
color=#006400>;
ri.
color=#006400>(
newimagedef
size=1>);
ri.Visible
color=#006400>=
true
color=#006400>;
ri.Orientation
color=#006400>=
new
color=#006400>(
p1,
color=#008b8b>new
Vector3d
size=1>(width,
color=#00008b>0
color=#00008b>0
), new
Vector3d
color=#006400>(
0
color=#006400>,
height,
color=#00008b>0
btr.
color=#006400>(
ri
tr.
color=#006400>(
ri,
color=#008b8b>true
color=#008000>
tr.
size=1>();
doclock.
size=1>();
which is
the RasterImageDef.
Supporting AutoCAD
2000 through 2009
I
this same problem.
href="http://www.objectarx.net/bbs/viewthread.php?tid=2500&extra=page%3D1"
target=_new...
Chris Bertschy
punished??
Message 5 of 10
   I have been trying to pass the
object rasterimagedef object with no results.  It continues to throw the
eNotinDatabase exception.  There is another  method used as a switch
called enablereactors().  Should i refrain from telling the transaction
manager to add the newly created rasterimagedef until the new raster image has
called the associaterasterdef... or does it not really matter.  I can't
tell if this is causing the problem.  I have tried it both ways and the
associaterasterdef() method will not work with the rasterimagedef.  Do I
have to fully commit() the transaction and start a new transaction before I
can attempt to feed it as a database object into the associate
method?
cbertschy
(the
open
and write-enabled).
with
any reactors.
through 2009
like:
entry does not exist in the database.
id that does not exist or that the raster image def is not being handle
via OE so I have no idea how this will look.
Thanks, Tony.
public
class
size=1>ACADutility
public
color=#a52a2a size=1>static
void
addimage
size=1>(
double
size=1>height
color=#ff0000 size=1>double
width
color=#006400 size=1>,
Point3d p1
Point3d p2
color=#006400 size=1>){
Document doc =
Application
size=1>.
DocumentManager
size=1>.
MdiActiveDocument
size=1>;
Database db =
doc.
size=1>Database
Editor ed =
doc.
size=1>Editor
Transaction tr =
db.
size=1>();
size=1>=
doc
size=1>.
LockDocument
using
size=1>(
tr)
BlockTable bt =
BlockTable
size=1>)
tr
size=1>.
GetObject
db
size=1>.
BlockTableId,
OpenMode.
size=1>ForRead
size=1>=
new
btr = (
size=1>tr
size=1>GetObject
size=1>bt
size=1>ModelSpace
size=1>OpenMode
size=1>ForWrite
RasterImageDef rid
size=1>=
new
ObjectId ImgDictID
size=1>=
RasterImageDef
size=1>.
size=1>db
if
size=1>(
ImgDictID
size=1>.
IsNull)
ImgDictID =
RasterImageDef
size=1>.
size=1>(
db);
rid.
color=#006400 size=1>;
rid.
size=1>Unit
size=1>Foot
rid.
rid.
rid.
size=1>();
size=1>=(
DBDictionary
size=1>)
tr
size=1>.
GetObject
ImgDictID
OpenMode
color=#006400 size=1>.
ForWrite
size=1>);
size=1>;
rasterimdefid =
imgdict
size=1>.
SetAt
size=1>rid
tr.
size=1>(
rid,
true
size=1>);
RasterImage ri =
new
size=1>RasterImage
size=1>= (
RasterImageDef
size=1>)
tr
size=1>.
GetObject
rid
size=1>.
ObjectId,
OpenMode.
size=1>ForWrite
being used to link the raster image to the dictionary definition.  this
does not work correctly.  It does work to make the added
drawing
newimagedef.
size=1>();
ri.ImageDefId
color=#006400>=
rid.ObjectId
color=#006400>;
ri.
color=#006400>(
newimagedef
size=1>);
ri.Visible
color=#006400>=
true
color=#006400>;
ri.Orientation
color=#006400>=
new
color=#006400>(
p1,
color=#008b8b>new
Vector3d
size=1>(width,
color=#00008b>0
color=#00008b>0
color=#008b8b>new
Vector3d
size=1>(0
color=#006400>,
height,
color=#00008b>0
btr.
color=#006400>(
ri
size=1>);
tr.
color=#006400>(
ri,
color=#008b8b>true
size=1>);
tr.
size=1>();
doclock.
size=1>();
which is
the RasterImageDef.
Supporting AutoCAD
2000 through 2009
I
My
href="http://www.objectarx.net/bbs/viewthread.php?tid=250...
Chris
Bertschy
punished??
Message 6 of 10
This works for me:
{code}
// Requires a reference to System.Windows.Forms
using System;
using System.Collections.Generic;
using
System.Text;
using Autodesk.AutoCAD.Runtime;
using
Autodesk.AutoCAD.ApplicationServices;
using
Autodesk.AutoCAD.EditorInput;
using
Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
using
System.Windows.Forms;
using System.IO;
using Acad =
Autodesk.AutoCAD.ApplicationServices.Application;
[assembly: CommandClass( typeof( RasterImageSample.Commands )
namespace RasterImageSample
   public class
Commands
      [CommandMethod(
"RASTER_SAMPLE" )]
      public static void
RasterCommand()
         Document doc =
Acad.DocumentManager.MdiActiveDocument;
OpenFileDialog ofd = new
OpenFileDialog();
         ofd.Filter
= "JPeg Files|*.jpg|Gif Files|*.gif|PNG
Files|*.png";
ofd.FilterIndex = 0;
ofd.Title = "Select Image File";
         if(
ofd.ShowDialog() == System.Windows.Forms.DialogResult.OK
            string
filename =
ofd.FileName;
using( Transaction trans = doc.TransactionManager.StartTransaction()
ObjectId idModel =
SymbolUtilityServices.GetBlockModelSpaceId(doc.Database);
BlockTableRecord ms = trans.GetObject( idModel, OpenMode.ForWrite) as
BlockTableRecord;
RasterImageDef imageDef = AddImageDef( doc.Database, trans, filename
if( imageDef != null
RasterImage image = new
RasterImage();
image.ImageDefId =
imageDef.ObjectId;
ObjectId imageId = ms.AppendEntity( image
if( imageId.IsNull
throw new Autodesk.AutoCAD.Runtime.Exception( ErrorStatus.NullObjectId
trans.AddNewlyCreatedDBObject( image, true
RasterImage.EnableReactors( true
image.AssociateRasterDef( imageDef
Point3d origin = (Point3d) Acad.GetSystemVariable( "VIEWCTR"
image.Orientation = new CoordinateSystem3d( origin, Vector3d.XAxis,
Vector3d.YAxis);
trans.Commit();
      public static RasterImageDef
AddImageDef( Database db, Transaction trans, string imageFilespec
         if( !File.Exists(
imageFilespec )
            throw
new FileNotFoundException( imageFilespec
         ObjectId idImageDict =
RasterImageDef.GetImageDictionary( db
         if( idImageDict.IsNull
idImageDict = RasterImageDef.CreateImageDictionary( db
            throw
new InvalidOperationException( "failed to get or create image dictionary"
         DBDictionary
imageDictionary = trans.GetObject( idImageDict, OpenMode.ForRead ) as
DBDictionary;
         if(
imageDictionary == null
            throw
new InvalidOperationException( "Failed to open image dictionary" );
RasterImageDef imageDef = new
RasterImageDef();
imageDef.SourceFileName =
imageFilespec;
imageDef.Load();
         String name =
RasterImageDef.SuggestName( imageDictionary, imageFilespec );
imageDictionary.UpgradeOpen();
ObjectId idEntry = imageDictionary.SetAt( name, imageDef
imageDictionary.DowngradeOpen();
         if(
idEntry.IsNull )
imageDef.Dispose();
imageDef =
null;
throw new InvalidOperationException( "Failed to add image definition to image
dictionary" );
trans.AddNewlyCreatedDBObject( imageDef, true );
         return
imageDef;
{code}
through 2009
like:
Thanks, Tony.
public
class
size=1>ACADutility
public
size=1>static
void
size=1>(
double
size=1>height
size=1>double
width,
Point3d p1,
size=1>Point3d p2
Document doc =
Application.
Database db =
doc.
size=1>Database
Editor ed =
doc.
size=1>Editor
Transaction tr =
db.
size=1>();
size=1>=
doc
size=1>.
LockDocument
using
size=1>(
tr)
BlockTable bt =
BlockTable)
size=1>tr
size=1>GetObject
size=1>db
size=1>BlockTableId
size=1>OpenMode
size=1>ForRead
size=1>=
new
btr = (
size=1>tr
size=1>GetObject
size=1>bt
size=1>ModelSpace
size=1>OpenMode
size=1>ForWrite
new
RasterImageDef
size=1>.
size=1>db
if
size=1>(
ImgDictID
size=1>.
IsNull)
ImgDictID =
RasterImageDef
size=1>.
size=1>(
db);
rid.
size=1>;
rid.
size=1>Unit
size=1>Foot
rid.
rid.
rid.
size=1>();
size=1>=(
DBDictionary
size=1>)
tr
size=1>.
GetObject
ImgDictID
size=1>,
OpenMode
size=1>.
ForWrite);
size=1>;
rasterimdefid =
imgdict.
rid);
tr.
size=1>(
rid,
true
size=1>);
RasterImage ri =
new
size=1>RasterImage
size=1>= (
RasterImageDef
size=1>)
tr
size=1>.
GetObject
rid
size=1>.
ObjectId,
OpenMode.
size=1>ForWrite
drawing
newimagedef.
size=1>();
ri.ImageDefId
color=#006400>=
rid.ObjectId
color=#006400>;
ri.
color=#006400>(
newimagedef
size=1>);
ri.Visible
color=#006400>=
true
color=#006400>;
ri.Orientation
color=#006400>=
new
color=#006400>(
p1,
color=#008b8b>new
Vector3d
size=1>(width,
color=#00008b>0
color=#00008b>0
), new
Vector3d
color=#006400>(
0
color=#006400>,
height,
color=#00008b>0
btr.
color=#006400>(
ri
tr.
color=#006400>(
ri,
color=#008b8b>true
color=#008000>
tr.
size=1>();
doclock.
size=1>();
which is
the RasterImageDef.
Supporting AutoCAD
2000 through 2009
I
this same problem.
target=_new...
Chris Bertschy
punished??
Message 7 of 10
This is a repeat of the code in the last post for people using the web interface:
{code}
using System;
using System.Text;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.DatabaseServices;
using System.Windows.Forms;
using System.IO;
using Acad = Autodesk.AutoCAD.ApplicationServices.Application;
[assembly: CommandClass( typeof( RasterImageSample.Commands ) )]
public class Commands
[CommandMethod( "RASTER_SAMPLE" )]
public static void RasterCommand()
Document doc = Acad.DocumentManager.MdiActiveDocument;
OpenFileDialog ofd = new OpenFileDialog();
ofd.Filter = "JPeg Files|*.jpg|Gif Files|*.gif|PNG Files|*.png";
if( ofd.ShowDialog() == System.Windows.Forms.DialogResult.OK )
string filename = ofd.FileName;
using( Transaction trans = doc.TransactionManager.StartTransaction() )
ObjectId idModel = SymbolUtilityServices.GetBlockModelSpaceId(doc.Database);
BlockTableRecord ms = trans.GetObject( idModel, OpenMode.ForWrite) as BlockTableRecord;
RasterImageDef imageDef = AddImageDef( doc.Database, trans, filename );
if( imageDef != null )
RasterImage image = new RasterImage();
image.ImageDefId = imageDef.ObjectId;
ObjectId imageId = ms.AppendEntity( image );
if( imageId.IsNull )
throw new Autodesk.AutoCAD.Runtime.Exception( ErrorStatus.NullObjectId );
trans.AddNewlyCreatedDBObject( image, true );
RasterImage.EnableReactors( true );
image.AssociateRasterDef( imageDef );
Point3d origin = (Point3d) Acad.GetSystemVariable( "VIEWCTR" );
image.Orientation = new CoordinateSystem3d( origin, Vector3d.XAxis, Vector3d.YAxis);
trans.Commit();
public static RasterImageDef AddImageDef( Database db, Transaction trans, string imageFilespec )
if( !File.Exists( imageFilespec ) )
throw new FileNotFoundException( imageFilespec );
ObjectId idImageDict = RasterImageDef.GetImageDictionary( db );
if( idImageDict.IsNull )
idImageDict = RasterImageDef.CreateImageDictionary( db );
throw new InvalidOperationException( "failed to get or create image dictionary" );
DBDictionary imageDictionary = trans.GetObject( idImageDict, OpenMode.ForRead ) as DBDictionary;
if( imageDictionary == null )
throw new InvalidOperationException( "Failed to open image dictionary" );
RasterImageDef imageDef = new RasterImageDef();
imageDef.SourceFileName = imageFilespec;
imageDef.Load();
String name = RasterImageDef.SuggestName( imageDictionary, imageFilespec );
ObjectId idEntry = imageDictionary.SetAt( name, imageDef );
if( idEntry.IsNull )
imageDef.Dispose();
imageDef = null;
throw new InvalidOperationException( "Failed to add image definition to image dictionary" );
return imageDef;
{code}
http://www.caddzone.com
Supporting AutoCAD 2000 through 2009
Introducing AcadXTabs 2010:
http://www.caddzone.com/acadxtabs/AcadXTabs2010.htm
"CB" wrote in message news:6061628@discussion.autodesk.com...
I have been trying to pass the object rasterimagedef object with no results. It continues to throw the eNotinDatabase exception. There is another method used as a switch called enablereactors(). Should i refrain from telling the transaction manager to add the newly created rasterimagedef until the new raster image has called the associaterasterdef... or does it not really matter. I can't tell if this is causing the problem. I have tried it both ways and the associaterasterdef() method will not work with the rasterimagedef. Do I have to fully commit() the transaction and start a new transaction before I can attempt to feed it as a database object into the associate method?
cbertschy
"Tony Tanzillo" wrote in message news:6061633@discussion.autodesk.com...
You don't pass any reactor id to AssociateRasterDef().
You pass what the name of that method implies (the
and write-enabled).
That's all there is to it. You don't need to deal with
any reactors.
"CB" wrote in message news:6061565@discussion.autodesk.com...
That is correct. When I code something like:
I get an error in autocad that tells me the entry does not exist in the database.
I am guessing that it is looking for a reactor id that does not exist or that the raster image def is not being handle properly. My question is really where in the code would I put the call to ri.associaterasterdef(rasterimagedef). I found a small tid bit that mentioned setting up a reactionid but nothing on how to handle this. Attached is my version. It is a work in progress. I am posting via OE so I have no idea how this will look.
Thanks, Tony.
public class ACADutility {
public static void addimage(double height, double width, Point3d p1, Point3d p2){
Document doc = Application.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
Editor ed = doc.Editor;
Transaction tr = db.TransactionManager.StartTransaction();
DocumentLock doclock = doc.LockDocument();
using (tr)
BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
BlockTableRecord btr = new BlockTableRecord();
btr = (BlockTableRecord)tr.GetObject(bt[BlockTableRecord.ModelSpace],OpenMode.ForWrite);
RasterImageDef rid = new RasterImageDef();
ObjectId ImgDictID = RasterImageDef.GetImageDictionary(db);
if (ImgDictID.IsNull)
ImgDictID = RasterImageDef.CreateImageDictionary(db);
rid.SourceFileName = "c:\\temp\\gis-image-test.jpg";
rid.ResolutionUnits = Unit.Foot;
rid.Load();
rid.OpenImage();
rid.UpdateEntities();
DBDictionary imgdict =(DBDictionary)tr.GetObject(ImgDictID, OpenMode.ForWrite);
ObjectId rasterimdefid;
rasterimdefid = imgdict.SetAt("image-SERVICE", rid);
tr.AddNewlyCreatedDBObject(rid, true);
RasterImage ri = new RasterImage();
RasterImageDef newimagedef = (RasterImageDef)tr.GetObject(rid.ObjectId, OpenMode.ForWrite);// this was my last ditch effort to get a raster image def to work. stuffing
//the original rid object into the method this not work so I attempted to get update object after the image dictionary update. Not that this should mattre but I can't
//get it to work upgrade open was something ignorant that I also tried. I had the ri.imagedfid = rid.objectid commented out but still did not work. all the
//example on the web show only this method being used to link the raster image to the dictionary definition. this does not work correctly. It does work to make the added image
//use the imagedefinition but does not add the neccesary reactor info to recognize that the imagedef has references in the drawing
newimagedef.UpgradeOpen();
ri.ImageDefId = rid.ObjectId;
ri.AssociateRasterDef(newimagedef);
ri.Visible = true;
ri.Orientation = new CoordinateSystem3d( p1, new Vector3d(width,0,0), new Vector3d(0,height,0));
btr.AppendEntity(ri);
tr.AddNewlyCreatedDBObject(ri, true);
tr.Commit();
doclock.Dispose();
"Tony Tanzillo" wrote in message news:6061475@discussion.autodesk.com...
Your code isn't calling RasterImage.AssociateImageDef(), which is
what creates the reactor and adds it to the RasterImageDef.
wrote in message news:6061357@discussion.autodesk.com...
Chris Bertschy
Message 8 of 10
Could not get your code to compile due to the different framework version I
must be using .net 2.0 (no System.Windows.Forms). I have been using .net
2.0 with sharpdevelop. Maybe this is why the Associate method is giving me
problems also. I am downloading the 1 gig sdk and will try again with the
.net 3.5 framework. Thank you for you example and time. I'll post my
results tonight.
cbertschy
news:6061643@discussion.autodesk.com...
interface:
{code}
using System;
using System.Text;
using System.IO;
ObjectId idModel =
filename );
"VIEWCTR" );
trans.Commit();
dictionary" );
imageDef.Load();
imageFilespec );
imageDef.Dispose();
imageDef = null;
return imageDef;
{code}
cbertschy
and write-enabled).
any reactors.
database.
Thanks, Tony.
p2){
using (tr)
btr =
rid.Load();
rid.OpenImage();
OpenMode.ForWrite);
mattre but I can't
all the
ri.Visible = true;
tr.Commit();
doclock.Dispose();
Chris Bertschy
Message 9 of 10
Correction. I forgot the reference to System.Windows.Forms. You code works
very well. I will need to study it better to see where I went wrong. Thank
you for your fine example.
cbertschy
"cbertschy" wrote in message
news:6061858@discussion.autodesk.com...
results tonight.
cbertschy
interface:
{code}
using System;
using System.Text;
using System.IO;
ObjectId idModel =
filename );
"VIEWCTR" );
trans.Commit();
dictionary" );
imageDef.Load();
imageFilespec );
imageDef.Dispose();
imageDef = null;
return imageDef;
{code}
cbertschy
and write-enabled).
any reactors.
database.
Thanks, Tony.
p2){
using (tr)
btr =
rid.Load();
rid.OpenImage();
OpenMode.ForWrite);
mattre but I can't
all the
ri.Visible = true;
tr.Commit();
doclock.Dispose();
Chris Bertschy
Message 10 of 10
Got it working. Thanks again for the example. I added a call to the
transaction manager to add the newly created image before calling the
associate method as you had done in your example. Worked great
cbertschy
news:6061860@discussion.autodesk.com...
cbertschy
results tonight.
cbertschy
interface:
{code}
using System;
using System.Text;
using System.IO;
ObjectId idModel =
filename );
"VIEWCTR" );
trans.Commit();
dictionary" );
imageDef.Load();
imageFilespec );
imageDef.Dispose();
imageDef = null;
return imageDef;
{code}
cbertschy
and write-enabled).
any reactors.
database.
Thanks, Tony.
p2){
using (tr)
btr =
rid.Load();
rid.OpenImage();
OpenMode.ForWrite);
mattre but I can't
all the
ri.Visible = true;
tr.Commit();
doclock.Dispose();
Chris Bertschy
”Boost
