.NET
"Unhandled exception has occurred in a component in your application." on 64 bit
1 REPLY 1
MADHAVI_1
1974 Views, 1 Reply
Any time while initializing autocad 2011 I get this error:
Application does not support just-in-time (JIT)
debugging. See the end of this message for details.
************** Exception Text **************
System.Exception: The component 'Autodesk.AutoCAD.AcInfoCenterConn.MyAutoCADBalloon' does not have a resource identified by the URI '/AcWindows;component/infocenteracconn/myautocadballoon.xaml'.
   at System.Windows.Application.LoadComponent(Object component, Uri resourceLocator)
   at Autodesk.AutoCAD.AcInfoCenterConn.MyAutoCADBalloon.InitializeComponent()
   at Autodesk.AutoCAD.AcInfoCenterConn.MyAutoCADBalloon..ctor()
   at Autodesk.AutoCAD.AcInfoCenterConn.MyAutoCADBalloon.ShowInfoBalloon()
   at Autodesk.AutoCAD.AcInfoCenterConn.InfoCenterManager.AcadApplication_Idle(Object sender, EventArgs e)
   at System.EventHandler.Invoke(Object sender, EventArgs e)
   at Autodesk.AutoCAD.ApplicationServices.Application.raise_Idle(Object value0, EventArgs value1)
   at Autodesk.AutoCAD.ApplicationServices.Application.OnIdle()
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.4952 (win7RTMGDR.050727-4900)
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll
acdbmgd
    Assembly Version: 18.1.0.0
    Win32 Version: 18.1.49.0.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202011/AcdbMgd.DLL
System
    Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
msvcm90
    Assembly Version: 9.0.30729.4926
    Win32 Version: 9.00.30729.4926
    CodeBase: file:///C:/Windows/WinSxS/amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.4926_none_08e1a05ba83f...
System.Xml
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Drawing
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
PresentationFramework
    Assembly Version: 3.0.0.0
    Win32 Version: 3.0.6920.5001 built by: Win7RTMGDR
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/PresentationFramework/3.0.0.0__31bf3856ad364e35/PresentationFra...
WindowsBase
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/WindowsBase/3.0.0.0__31bf3856ad364e35/WindowsBase.dll
PresentationCore
    CodeBase: file:///C:/Windows/assembly/GAC_64/PresentationCore/3.0.0.0__31bf3856ad364e35/PresentationCore.dll
AdApplicationFrame
    Assembly Version: 0.0.0.0
    Win32 Version: 3.0.264.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202011/AdApplicationFrame.DLL
AdWindows
    Assembly Version: 3.0.263.0
    Win32 Version: 3.0.263.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202011/AdWindows.DLL
PresentationFramework.Aero
    Win32 Version: 3.0.6920.4902 built by: NetFXw7
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/PresentationFramework.Aero/3.0.0.0__31bf3856ad364e35/Presentati...
acmgd
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202011/acmgd.DLL
System.Core
    Assembly Version: 3.5.0.0
    Win32 Version: 3.5.30729.4926 built by: NetFXw7
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Core/3.5.0.0__b77a5c561934e089/System.Core.dll
System.Configuration
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configura...
AcWindows
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202011/AcWindows.DLL
AcWindows.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202011/en-US/AcWindows.resources.DLL
acmgd
    CodeBase: file:///C:/Aveva/P%26ID/Install/Exe/ProjectWizard/acmgd.dll
System.Windows.Forms
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.F...
AcTcMgd
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202011/AcTcMgd.DLL
AcCui
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202011/AcCui.DLL
ContextualTabSelectorRules
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202011/AcWindows.dll
ManagedMC3
    Assembly Version: 4.11.0.0
    Win32 Version: 4.12.0.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202011/ManagedMC3.DLL
AcWindows
    CodeBase: file:///C:/Aveva/P%26ID/Install/Exe/ProjectWizard/AcWindows.dll
AcLayer
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202011/AcLayer.DLL
AcLayer.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202011/en-US/AcLayer.resources.DLL
************** JIT Debugging **************
Application does not support Windows Forms just-in-time (JIT)
debugging. Contact the application author for more
information.
I am working on Windows 7 Professional (64-bit operating system).
I am creating a project specific profile for which i need to initialize AutoCAD for creating profile. Same code is working fine with 32-bit operating system,but while working on 64-bit system I am getting the error.
Any help will be appreciated.
Thanks in Advance.
1 REPLY 1
amy
in reply to: MADHAVI_1
Me to
Then I check the reference Dll , The copy file become true
I set it To False , Then Del .../debug files
Retest ,and it's OK
”Boost
