.NET
Valued Contributor
HEnnulat
Message 11 of 24 (684 Views)
Re: "System.Windows.Data Error: ## : BindingExpression path error...".?
10-21-2009 08:01 AM in reply to: HEnnulat
Autodesk seemed to make a big deal about "copy local" always needing to be false. But this is something I could try.. Will advise...
The reason I am using the dlls in the SDK is because this was the recommendation I read in some Autodesk reference. I believe it was in the developers guide.
Are you aware of different version of the acDBmgd and acmgd.dll files for the different versions of AutoCAD 2010 (plain, electrical, civil, etc)? Or was this just a speculation to help figure out what might be different between our systems?
A co-worker reported to me this morning that he gets these binding errors also using AutoCAD 2010 the plain version. He is using VB.Net 2005 however.
*Tony Tanzillo
Message 12 of 24 (684 Views)
10-21-2009 04:28 PM in reply to: HEnnulat
You should always have CopyLocal set to false for those
two assemblies.
AFAIK, all AutoCAD based products use the same version
of the Ac*Mgd.dll assemblies.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2010
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message news:6275245@discussion.autodesk.com...
developers guide.
Valued Contributor
HEnnulat
Message 13 of 24 (684 Views)
10-29-2009 08:30 AM in reply to: HEnnulat
Here is an update on my binding erros when I run the code in debug mode. (see attached).
They are significant fewer! Only about 12 messages. Not sure why? I'm not aware that I did anything differently from when I last reported on getting my Visual Studio 2008 set up to run with AutoCAD extensions.
(See the post titled "Cann't Get VB.Net to Work with AutoCAD 2010" for background info).
Active Member
phanmanhquyet
Message 14 of 24 (684 Views)
12-28-2009 04:22 PM in reply to: HEnnulat
Hi HEnnulat,
I develop .NET with Revit Structure 2010 and have same problem with you. Have you solve that problem? I have spend 3 days but still stuck.
First i installed VS Express 2010, it can not run. Later i try with VS 2008 profession but still the same event with "Hello World" sample.
Very appreciate if anyone can help.
Valued Contributor
HEnnulat
Message 15 of 24 (684 Views)
12-29-2009 10:13 AM in reply to: HEnnulat
No Nothing New. I just learned to live with the remaining errors which while decreased still remained as already discussed in this thread.
I never got any additional help on this. The best info suggests that this is fairly "normal", yet some have indicated they do not get tese "binding errors". Edited by: HEnnulat on Dec 29, 2009 12:13 PM
Valued Contributor
fallright
Message 16 of 24 (684 Views)
01-10-2010 11:36 AM in reply to: HEnnulat
A have the same problem with Acad Civil 3D and a lot of other errors (zie attachments). And in my Case the code works with the (annoying) errors.
Valued Contributor
fallright
Message 17 of 24 (684 Views)
01-11-2010 12:52 AM in reply to: HEnnulat
Hi HEnnulat,
I want to ask you something. When you start up Autocad, a popup-window gives you the opportunity to view some tutorials. There is a checkbox "don't show this anymore". I have done this and a lot of errors disapaered. Is this a solution for you ?
*Tony Tanzillo
Message 18 of 24 (684 Views)
01-11-2010 01:27 AM in reply to: HEnnulat
I only see these errors when the CopyLocal property for any referenced assembly
that exists in the AutoCAD folder is set to true.
The error occurs because the resource satellite assembly for the current culture
is not being found in the folder where the assembly that uses it is located, as
would be the case for any referenced AutoCAD assembly whose CopyLocal property
is true, *and* the assembly has not already been loaded into AutoCAD before your
code tries to use it.
wrote in message news:6315576@discussion.autodesk.com...
Active Contributor
hperison
Message 19 of 24 (684 Views)
01-13-2010 10:52 AM in reply to: HEnnulat
Hennulat, This is to simply inform you that you are not alone in this matter as I too have been attempting to resolve this issue.
These messages are displayed within my Visual Basic 2008 Immediate Window during project execution in Debug mode when Autocad is first launched. These appear to have no effect on the project functionality, however I do agree that it is rather disconcerting to see them.
Valued Contributor
HEnnulat
Message 20 of 24 (684 Views)
01-15-2010 11:21 AM in reply to: HEnnulat
No, not that I know of. I have since moved on to other things, so I'm going by memory a bit, but I'm pretty sure I don't get anything about tutorials... must have turned these off almost right away. Thanks for the thought.
