.NET
.NET
Moderator
Alexander.Rivilis
Message 11 of 18 (207 Views)
Re: "Clone" an object from one drawing to another with modifications p
12-26-2012 10:30 PM in reply to: NovayaEra
freestyler8 wrote:
How to find cloned entities in destination dwg after cloning? When it was cloned, it got new ObjectID, truly?
All ObjectID's of cloned entities are in acIDMap as a idPair.Value
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
NovayaEra
Message 12 of 18 (202 Views)
12-27-2012 12:15 AM in reply to: cwelkusl
I make so:
  For Each idp As IdPair In acIDMap
       Try
              Dim acEnt As Object = acDestTrans.GetObject(idp.Value, OpenMode.ForWrite)
               acEnt.TransformBy(m) 'm as Matrix3d
       Catch
       End Try
  Next
 But cloned objects was Text, Line and Block. This code moves only Text. Line and Block are disappear
Moderator
Alexander.Rivilis
Message 13 of 18 (191 Views)
12-27-2012 01:24 AM in reply to: NovayaEra
freestyler8 wrote:
I make so:
       Try
       Catch
       End Try
  Next
You have to move only entities that acEnt.OwnerId is equal acDestModelSpace.ObjectId
NovayaEra
Message 14 of 18 (181 Views)
12-27-2012 04:24 AM in reply to: Alexander.Rivilis
Yes, acEnt.OwnerId is equal acDestModelSpace.ObjectId for three objects: Line, DBText and BlockReference. And successfully moved only DBtext.  Block and Line becomes invisible, but I can see it's central points (it's moved).
Moderator
Alexander.Rivilis
Message 15 of 18 (177 Views)
12-27-2012 04:28 AM in reply to: NovayaEra
Maybe layer's of BlockReference and Line is off or frozen, or property Visible of those entities is False
P.S.: Without full code and a sample dwg-file I can not help you.
NovayaEra
Message 16 of 18 (173 Views)
12-27-2012 04:43 AM in reply to: Alexander.Rivilis
No, it's Visible property is True, layer is same that DText's layer.  And if I don't move it, it's visible :-(
this code:
Public Function InsertAll(sFN As String, ipt As Point3d) As Boolean
        Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
        Dim acdocDest As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
        Dim acDestDB As Database = acdocDest.Database
        Dim acObjIDs As ObjectIdCollection = New ObjectIdCollection()
        Dim acIDMap As IdMapping = New IdMapping()
        Try
            Using acDocLock As DocumentLock = acdocDest.LockDocument()
                Using acSourceDB As New Database(False, True)
                    Using acSourceTrans As Transaction = acSourceDB.TransactionManager.StartTransaction()
                        acSourceDB.ReadDwgFile(sFN, IO.FileShare.Read, True, "")
                        Using acDestTrans As Transaction = acDestDB.TransactionManager.StartTransaction()
                            Dim acSourceBlockTable As BlockTable = acSourceTrans.GetObject(acSourceDB.BlockTableId, OpenMode.ForRead)
                            Dim acSourceModelSpace As BlockTableRecord = acSourceTrans.GetObject(acSourceBlockTable(BlockTableRecord.ModelSpace), OpenMode.ForRead)
                            Dim acDestBlockTable As BlockTable = acDestTrans.GetObject(acDestDB.BlockTableId, OpenMode.ForWrite)
                            Dim acDestModelSpace As BlockTableRecord = acDestTrans.GetObject(acDestBlockTable(BlockTableRecord.ModelSpace), OpenMode.ForWrite)
                            For Each acObjID As ObjectId In acSourceModelSpace
                                acObjIDs.Add(acObjID)
                            Next acObjID
                            'Copy
                            acSourceDB.WblockCloneObjects(acObjIDs, acDestModelSpace.ObjectId, acIDMap, DuplicateRecordCloning.Ignore, False)
                            'Move
                            ed.WriteMessage(ipt.ToString)
                            Dim origin As Point3d = New Point3d(0, 0, 0)
                            Dim v As Vector3d = New Vector3d(0, 0, 0)
                            Dim m As Matrix3d = Matrix3d.AlignCoordinateSystem(origin, v, v, v, ipt, v, v, v)
                                Try
                                    If acEnt.OwnerID.ToString = acDestModelSpace.ObjectId.ToString Then
                                        ed.WriteMessage(vbLf & acEnt.GetType.ToString)
                                        ed.WriteMessage(vbLf & acEnt.OwnerID.ToString)
                                        ed.WriteMessage(vbLf & "moved")
                                    End If
                                Catch
                                    ed.WriteMessage(vbLf & "err")
                                End Try
                            Next
                            acDestTrans.Commit()
                        End Using
                    End Using
                End Using
            End Using
        Catch ex As Exception
            MsgBox("Error importing objects: " & ex.Message & vbCrLf & vbTab & ex.StackTrace, MsgBoxStyle.Critical)
        End Try
    End Function
 this result:
Autodesk.AutoCAD.DatabaseServices.BlockReference
(8796083599856)
moved
Autodesk.AutoCAD.DatabaseServices.DBText
(8796083599856)
moved
Autodesk.AutoCAD.DatabaseServices.Line
(8796083599856)
moved
Moderator
Alexander.Rivilis
Message 17 of 18 (166 Views)
12-27-2012 04:55 AM in reply to: NovayaEra
Very strange code:
 Maybe:
Dim m As Matrix3d = Matrix3d.Displacement(ipt - origin)
NovayaEra
Message 18 of 18 (148 Views)
12-27-2012 09:55 PM in reply to: Alexander.Rivilis
Yes, it works! Thank you very much!! С наступающим Вас! :-)
