.NET
.NET
Valued Mentor
AubelecBE
Message 1 of 6 (207 Views)
Question : How i can keep variable after quit the main function of the dll
207 Views, 5 Replies
02-12-2013 02:31 PM
Hi .
I want to load my DLL, launch the function with a command. After i quit and lauch the same command. (The DLL is already in memory).
(using sessionflags.)
It is possible to keep the variable i have used in the the first launch for use in the second launch ?
The main function is for adding block in a collection (the user select block). The programm quit, so the user can open a another dwg and run the main function for adding another  block. (i memorize name, handle, name of file etc..)
Another question : it is possible to create a form in autocad but if the only active document is closed, the form is not closed and visible. ?
All there question is for create a best solution for manage my collection of block.
thank.
_gile
Message 2 of 6 (187 Views)
Re : Question : How i can keep variable after quit the main function of the dll
02-12-2013 10:17 PM in reply to: AubelecBE
If your Command is defined within a class (as it should be), any field of this class will be accessible for the Command method (or any other method of this class) each time the command is launched.
If you want the field(s) to be shared between different dranwings, you have to set them static (Shared in VB).
Gilles Chanteau
Valued Mentor
AubelecBE
Message 3 of 6 (162 Views)
02-14-2013 04:18 AM in reply to: _gile
ok thanks.
But how i can know if it is the first laucnh of the command or not ?
I dont use  static variable so..
Active Contributor
DouceDeux
Message 4 of 6 (153 Views)
Re: Question : How i can keep variable after quit the main function of the dll
02-14-2013 05:54 AM in reply to: AubelecBE
If you want data to persist between command calls within the same session of AutoCAD, you're gonna have to use static variables.
When describing your scenario, please be clear and differenciate program quitting (closing AutoCAD) from closing a document. You say "After i quit"; do you mean to say "After the command has ended"? There is no way to make data persist if you close the acad.exe other than external files and the clipboard.
You also say "The programm quit, so the user can open a another dwg and run the main function".
Do you mean to say "The user closes the current DWG and opens up another one where he uses the command again"
About your form question, you can register the event for when documents are closed within the document manager,  usually in the myPlugin file inside the initialize function.
Application.DocumentManager.DocumentDestroyed += new DocumentDestroyedEventHandler(DocumentManager_DocumentDestroyed);
void DocumentManager_DocumentDestroyed(object sender, DocumentDestroyedEventArgs e)
  myFormClass newForm = new myFormClass();
Application.ShowModalWindow(newForm); }
The above event is for when the DWG has been completely closed, you don't have access to the document or its database anymore. The e argument only holds the name of the file destroyed. If you need to have access to the document and its database, you would need to use:
Application.DocumentManager.DocumentToBeDestroyed += new DocumentCollectionEventHandler(DocumentManager_DocumentToBeDestroyed);
void DocumentManager_DocumentToBeDestroyed(object sender, DocumentCollectionEventArgs e)
 Here the sender object is the document manager, so you can cast it like this if you need to:
DocumentCollection newDC = sender as DocumentCollection;
The argument e is the document about to be destroyed. You can cast it the same way:
Document newDocument = e as Document;
_gile
Message 5 of 6 (135 Views)
02-14-2013 10:08 AM in reply to: AubelecBE
You can try this little sample (may be self explanatory)
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Runtime;
[assembly: CommandClass(typeof(PerDocumentOrSessionVariablesSample.CommandMethods))]
namespace PerDocumentOrSessionVariablesSample
    public class CommandMethods
        private string perDocument = "perDocumentDefault";
        private static string perSession = "perSessionDefault";
        [CommandMethod("Test", CommandFlags.Session)]
        public void Test()
            Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
            PromptStringOptions pso = new PromptStringOptions("\nEnter the per session value: ");
            pso.DefaultValue = perSession;
            pso.UseDefaultValue = true;
            PromptResult pr = ed.GetString(pso);
            if (pr.Status != PromptStatus.OK) return;
            perSession = pr.StringResult;
            pso.Message = "\nEnter the per document value: ";
            pso.DefaultValue = perDocument;
            perDocument = pr.StringResult;
            ed.WriteMessage("\nPer session value: {0}, per document value: {1}", perSession, perDocument);
Gilles Chanteau
Valued Mentor
AubelecBE
Message 6 of 6 (125 Views)
02-15-2013 04:01 AM in reply to: _gile
Thanks for the reply.
For me my app is the DLL i have loaded. Autocad is always running. I dont close Autocad.
I have to test all this for learn the best use of static variable.
