.NET
Question about the UI from a .NET plugin
4 REPLIES 4
btmsoftware
517 Views, 4 Replies
I seem to remember reading somewhere, but I can't remember where that it is possible to manipulate some of the AutoCAd forms from a .NET plugin
For example, when a user runs the Attach Command, I want to be able to programatically set the Path type to No Path and disable the control so it can;t be changed manually
Anybody has any idea ?
4 REPLIES 4
Daniel.Du
in reply to: btmsoftware
Are you saying the "filedia" variable?  Set filedia to 0 if you do not want to see the open/save dialougue.
Daniel Du
Developer Technical Services
Autodesk Developer Network
btmsoftware
in reply to: Daniel.Du
Daniel,
No, I'm saying for example the XRef attachment form (where you define the attachment paramters such as insertion pointm scale, roation, attachment/overlay, etc...)
Sorry, I do think, there is any API to modify the behavior of attach external reference dialog box.
Virupaksha Aithal KM
that's what I was expecting to be honest. thanx any way for confirming
”Boost
