.NET
Question about SaveFileDialog
3 REPLIES 3
simonkx
813 Views, 3 Replies
I want to invoke the savefiledialog to save a dwg-file,and my code is like this:
Autodesk.AutoCAD.Windows.SaveFileDialog sfd = new Autodesk.AutoCAD.Windows.SaveFileDialog("File save as","Drawing1.dwg","dwg","saving file",Autodesk.AutoCAD.Windows..SaveFileDialog.SaveFileDialogFlags.DefaultIsFolder);
sfd.ShowDialog();
But I found nothing where the file had been saved.Is there anything wrong with the code?Are there some examples about the savefiledialog with C#?
Thanks for your help!
3 REPLIES 3
simonkx
in reply to: simonkx
I have changed the code like this:
Autodesk.AutoCAD.Windows.SaveFileDialog sfd = new Autodesk.AutoCAD.Windows.SaveFileDialog("File save as","Drawing1.dwg","dwg","saving file",Autodesk.AutoCAD.Windows.SaveFileDialog.SaveFileDialogFlags.DefaultIsFol der);
if( sfd.ShowDialog() == DialogResult.OK)
db.Saveas(sfd.filename,DwgVersion.Current);
but it's still wrong.
someone could show me any examples of C#?
simonkx
The problem has been resolved!
ampplee
Could you clue me in on your resolution?
”Boost
