.NET
Active Contributor
chase.hochstrasser
Message 1 of 3 (183 Views)
Query report text
183 Views, 2 Replies
12-19-2013 12:17 PM
I would like to create a text file with from a report. here is my code so far....
                    '' Clear the existing Query
                    Dim qryModel As QueryModel = proj.CreateQuery()
                    qryModel.Clear()
                    Dim qryBranch As New QueryBranch(Constants.JoinOperator.OperatorAnd)
                    '' Property Condition
                    Dim propertyCondition As PropertyCondition = New PropertyCondition
                    propertyCondition.JoinOperator = Constants.JoinOperator.OperatorAnd
                    propertyCondition.PropertyType = Constants.PropertyType.Layer
                    propertyCondition.ConditionOperator = Constants.ConditionOperator.ConditionEqual
                    propertyCondition.Value = "CP*"
                    qryBranch.AppendOperand(propertyCondition)
                    qryModel.Define(qryBranch)
                    qryModel.Mode = Constants.QueryType.QueryReport
                    qryModel.ReportTemplate.AddLine(":CIRCUIT@CIRCUIT")
                    qryModel.ReportTemplate.AddLine(".DWGNAME")
                    qryModel.Execute(dwgSet)
                    qryModel.Run()
 can you help me to send data to a text file?
is that the line you are missing (based on your code):
      'last lines based on your code (after adding .DWGNAME):
      'define your output file
      qryModel.ReportTemplate.FileName = "C:\TEMP\ReportResult.TXT"
      'removed ... qryModel.Execute(dwgSet)
      qryModel.Run()
- alfred -
Alfred.NESWADBA
Message 2 of 3 (148 Views)
Re: Query report text
12-20-2013 01:22 AM in reply to: chase.hochstrasser
      qryModel.Run()
- alfred -
Alfred NESWADBA
Active Contributor
chase.hochstrasser
Message 3 of 3 (128 Views)
12-20-2013 08:30 AM in reply to: chase.hochstrasser
Correct! Thanks again.
