.NET
franciscocsilva
Message 1 of 8 (464 Views)
Purgeall
464 Views, 7 Replies
02-25-2013 03:13 AM
Needed help in the following solution.
doc.SendStringToExecute("_-Purge _A _* _N ", True, False, False)
Francisco Silva
www.lojadosdesenhadores.blogspot.com
What help do you need?
Maybe simplest sample:
using System;
using System.Reflection;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.EditorInput;
[assembly: CommandClass(typeof(Rivilis.Purge))]
namespace Rivilis
public class Purge
[CommandMethod("MyPurgeAll")]
static public void MyPurgeAll()
// For AutoCAD 2013+
object adoc = Application.DocumentManager.MdiActiveDocument.GetAcadDocument();
// For AutoCAD 2012-
// object adoc = Application.DocumentManager.MdiActiveDocument.AcadDocument;
if (adoc != null) {
adoc.GetType().InvokeMember("PurgeAll",BindingFlags.InvokeMethod, null, adoc, null);
This code have to work in both AutoCAD 2012 (and 2011, 2010...) and AutoCAD 2013:
using System;
namespace Rivilis
public class Purge
Document doc = Application.DocumentManager.MdiActiveDocument;
object adoc = null;
if (Application.Version.Major < 19) {
// For AutoCAD 2012- (i.e. 2012, 2011, 2010, ...)
adoc = doc.GetType().InvokeMember("AcadDocument",
BindingFlags.GetProperty, null, doc, null);
} else {
// For AutoCAD 2013+ (i.e. 2013, 2014 (???), ...)
Type ext = typeof(Autodesk.AutoCAD.Windows.Menu).Assembly
.GetType("Autodesk.AutoCAD.ApplicationServices.DocumentExtension", true); MethodInfo GetAcadDocumentMethod = ext.GetMethod("GetAcadDocument", BindingFlags.Public | BindingFlags.Static); adoc = GetAcadDocumentMethod.Invoke(doc, new object[1] { doc }); } if (adoc != null) { adoc.GetType().InvokeMember("PurgeAll", BindingFlags.InvokeMethod, null, adoc, null); } } } }
Moderator
Alexander.Rivilis
Message 2 of 8 (443 Views)
Re: Purgeall
02-25-2013 06:44 AM in reply to: franciscocsilva
using System;
namespace Rivilis
  public class Purge
      if (adoc != null) {
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
franciscocsilva
Message 3 of 8 (416 Views)
Re: Purgeall
02-25-2013 10:41 AM in reply to: Alexander.Rivilis
Thanks Alexander
i have this message:
Error 1 'GetAcadDocument' is not a member of 'Autodesk.AutoCAD.ApplicationServices.Document'.
Francisco Silva
Valued Contributor
e.g.
Message 4 of 8 (401 Views)
Re: Purgeall
02-25-2013 12:59 PM in reply to: franciscocsilva
Hi Alexander,
the code works ok, but I have though a question: I have a drawing that was last saved in paper space (paper space being active space).
When I open up the drawing and try to run the code (just as the first command in the drawing), it doesn't run. Although if I enter model space through viewport or switch back and forth between model space and paper space, the code will run as supposed to.
I don't know what is missing.
e.g.
Moderator
Alexander.Rivilis
Message 5 of 8 (399 Views)
Re: Purgeall
02-25-2013 01:40 PM in reply to: franciscocsilva
franciscocsilva wrote:
Thanks Alexander
This is because you did not read the comments in the program. Read them carefully.
e.g. wrote:
...When I open up the drawing and try to run the code (just as the first command in the drawing), it doesn't run. Although if I enter model space through viewport or switch back and forth between model space and paper space, the code will run as supposed to...
Sorry but I can not reproduce this behavior.
Distinguished Contributor
area51visitor
Message 6 of 8 (372 Views)
Re: Purgeall
02-26-2013 02:58 AM in reply to: Alexander.Rivilis
I was just telling myself, as an uneducated programming hobbyiest writing addins for myself only, that modifying geometry in CAD so far has been fairly straight forward, but there was no way I could figure out how to "purge all".... VUALA! Magic appears at Autodesk :smileyhappy:
Thanks Alexander (or is it Alex?)
One more question... I couldn't help but notice the difference in the adoc dealio... everything I've written for myself has been for 2012... are you showing me that I'll have to update every flippin acdoc in my code when I update to 2013?  sad face lol
Thanks!
- Brian
"Very funny, Scotty. Now beam down my clothes."
franciscocsilva
Message 7 of 8 (361 Views)
Re: Purgeall
02-26-2013 04:07 AM in reply to: franciscocsilva
Resolved
Thanks Alexander
Francisco Silva
Moderator
Alexander.Rivilis
Message 8 of 8 (355 Views)
Re: Purgeall
02-26-2013 05:05 AM in reply to: area51visitor
using System;
namespace Rivilis
  public class Purge
      object adoc = null;
      } else {
