.NET
Valued Contributor
1 Kudo
Post 1 of 2
Purge font (shape)
193 Views, 1 Replies
09-18-2013 12:12 PM
Hello guys (and girls),
I have a routine to purge a drawing. I'm able to purge layers, blocks, material, dimstyle, linetype, mleaderstyle, mlinestyle, textstyle and table style. But i'm not able to figure out how to purge shape (font). Here an extract of my routine:
Public Enum ItemType As Integer
            Block = 0
            Layer = 1
            Material = 2
            Dimstyle = 3
            MLeaderstyle = 4
            MLine = 5
            Shape=6
            TableStyle = 7
            TextStyle = 8
            Linetype = 9
 End Enum
        Private Function PurgeItem(ByVal ItemType As ItemType, Optional ByVal ItemName As String = "") As Integer
            Dim returnCode As Integer = 0
            Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
            Dim acCurDb As Database = acDoc.Database
            '' Start a transaction
            Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
                '' Create an ObjectIdCollection to hold the object ids for each table record
                Dim acObjIdColl As ObjectIdCollection = New ObjectIdCollection()
                'Detect which table to retrieve
                Select Case ItemType.ToString
                    Case "Layer"
                        '' Open the Layer table for read
                        Dim acLyrTbl As LayerTable
                        acLyrTbl = acTrans.GetObject(acCurDb.LayerTableId, _
                                                     OpenMode.ForRead)
                        '' Step through each layer and add it to the ObjectIdCollection
                        For Each acObjId As ObjectId In acLyrTbl
                            acObjIdColl.Add(acObjId)
                        Next
                    Case "Block"
                        '' Open the Block table for read
                        Dim acBlkTbl As BlockTable
                        acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, _
                                                     OpenMode.ForRead)
                        '' Step through each block and add it to the ObjectIdCollection
                        For Each acObjId As ObjectId In acBlkTbl
                            If ItemName = "" Then
                            Else
                                Dim acblock As BlockTableRecord
                                acblock = acTrans.GetObject(acObjId, OpenMode.ForRead)
                                If ItemName.EndsWith("*") Then
                                    Dim strTemp = ItemName.Substring(0, ItemName.IndexOf("*"))
                                    If acblock.Name.StartsWith(strTemp) Then
                                ElseIf acblock.Name.ToUpper.Trim = ItemName.ToUpper.Trim Then
                        Next
                    Case "Material"
                        '' Open the Material table for read
                        Dim acMaterialTbl As DBDictionary
                        acMaterialTbl = acTrans.GetObject(acCurDb.MaterialDictionaryId, _
                                                     OpenMode.ForRead)
                        '' Step through each material and add it to the ObjectIdCollection
                        For Each dicID In acMaterialTbl
                            Dim key As String = dicID.Key
                            If (key <> "ByBlock") AndAlso (key <> "ByLayer") AndAlso (key <> "Global") Then
                                acObjIdColl.Add(dicID.Value)
                        Next
                    Case "Dimstyle"
                        '' Open the dimstyle table for read
                        Dim acDimTbl As DimStyleTable
                        acDimTbl = acTrans.GetObject(acCurDb.DimStyleTableId, _
                                                     OpenMode.ForRead)
                        '' Step through each dimstyle and add it to the ObjectIdCollection
                        For Each acObjId As ObjectId In acDimTbl
                        Next
                    Case "Linetype"
                        '' Open the Linetype table for read
                        Dim acLinetype As LinetypeTable
                        acLinetype = acTrans.GetObject(acCurDb.LinetypeTableId, _
                                                     OpenMode.ForRead)
                        '' Step through each linetype and add it to the ObjectIdCollection
                        For Each acObjId As ObjectId In acLinetype
                        Next
                    Case "MLeaderstyle"
                        '' Open the mleaderstyle table for read
                        Dim acMLeaderTbl As DBDictionary
                        acMLeaderTbl = acTrans.GetObject(acCurDb.MLeaderStyleDictionaryId, _
                                                     OpenMode.ForRead)
                        '' Step through each multileaderstyle and add it to the ObjectIdCollection
                        Dim dicID As DBDictionaryEntry
                        For Each dicID In acMLeaderTbl
                            If dicID.Value.IsValid Then
                        Next
                    Case "MLinestyle"
                        '' Open the mlinestyle table for read
                        Dim acMLineTbl As DBDictionary
                        acMLineTbl = acTrans.GetObject(acCurDb.MLeaderStyleDictionaryId, _
                                                     OpenMode.ForRead)
                        '' Step through each mlinestylee and add it to the ObjectIdCollection
                        For Each dicID In acMLineTbl
                        Next
                    Case "Shape"
                        '' Open the Shape table for read
                        Dim acShapeTbl as ??????? or
                        Dim acShapeTbl As DBDictionary
                        acShapeTbl = acTrans.GetObject(acCurDb.???????, _
                                                      OpenMode.ForRead)
                        '' Step through eachshape and add it to the ObjectIdCollection
                        For Each dicID In acShapeTbl
                        Next
                    Case "Textstyle"
                        '' Open the Textstyle table for read
                        Dim acTextTbl As TextStyleTable
                        acTextTbl = acTrans.GetObject(acCurDb.TextStyleTableId, _
                                                     OpenMode.ForRead)
                        '' Step through each textstyle and add it to the ObjectIdCollection
                        For Each acObjId As ObjectId In acTextTbl
                        Next
                    Case "Tablestyle"
                        Dim acTableTbl As DBDictionary
                        acTableTbl = acTrans.GetObject(acCurDb.TableStyleDictionaryId, _
                                                     OpenMode.ForRead)
                        For Each dicID In acTableTbl
                        Next
                End Select
                '' Remove the layers (or other object)  that are in use and return the ones that can be erased
                acCurDb.Purge(acObjIdColl)
                '' Step through the returned ObjectIdCollection
                For Each acObjId As ObjectId In acObjIdColl
                    Using locked As Autodesk.AutoCAD.ApplicationServices.DocumentLock = acDoc.LockDocument()
                        Dim obj As DBObject = acTrans.GetObject(acObjId, OpenMode.ForWrite)
                        'Dim acSymTblRec As SymbolTableRecord
                        'acSymTblRec = acTrans.GetObject(acObjId, _
                        '                                OpenMode.ForWrite)
                        Try
                            '' Erase the unreferenced layer
                            obj.Erase(True)
                            'acSymTblRec.Erase(True)
                            returnCode = returnCode + 1
                        Catch Ex As Autodesk.AutoCAD.Runtime.Exception
                            '' Layer (or other object) could not be deleted
                            Application.ShowAlertDialog("Error:" & vbLf & Ex.Message)
                        End Try
                    End Using
                Next
                '' Commit the changes and dispose of the transaction
                acTrans.Commit()
            End Using
            Return returnCode
end function
In the shape Section I don't know which table or dictionary to use???
Anyone have an idea???
André
ADN Support Specialist
100 Kudos
Post 2 of 2
Re: Purge font (shape)
09-25-2013 02:12 AM in reply to: andred
To purge shape files, you will need to gather the TextStyleTableRecords.
Balaji
Developer Technical Services
Autodesk Developer Network
Post to the Community
New Post
