.NET
.NET
New Member
0 Kudos
Post 1 of 4
Accepted Solution
Prompt user to pick point on circle with given radius
496 Views, 3 Replies
07-25-2013 02:04 AM
Hi!
I'm searching for a solution to achieve the following:
I need my users to pick a point p, enter a distance r and a direction v. A new point should be created r units away in vectorial direction. Therefore, the new point is located on an imaginary circle with radius r and center p.
Currently, the user picks the first point and enters a distance. Then, he has to pick another point (Editor.GetPoint with UseBasePoint = true), I calculate the vector between both points, create a new point (with location = BasePoint.location) and translate it d units in vectorial direction. This works of course, but the problem is, that the user doesn't see directly, where his new point is located, since he may pick a point closer to or farther away then r units.
Naively spoken, I want to restrict the line between BasePoint and new point while prompting the user to a fixed length. Is there any way to achieve this? Native calls to ObjectARX-methods would be also okay.
Thank you!
Maybe you can use a Jig to show the point durring the prompt for angle.
using System;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.GraphicsInterface;
using Autodesk.AutoCAD.Runtime;
[assembly: CommandClass(typeof(JigPointOnCircleSample.CommandMethods))]
namespace JigPointOnCircleSample
public class CommandMethods
[CommandMethod("Test", CommandFlags.Modal)]
public void Test()
Document doc = Application.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
Editor ed = doc.Editor;
int pdmode = db.Pdmode;
double pdsize = db.Pdsize;
try
db.Pdmode = 3;
db.Pdsize = -3.0;
PromptPointResult ppr = ed.GetPoint("\nCenter: ");
if (ppr.Status != PromptStatus.OK) return;
PromptDistanceOptions pdo = new PromptDistanceOptions("\nRadius: ");
pdo.BasePoint = ppr.Value;
pdo.UseBasePoint = true;
PromptDoubleResult pdr = ed.GetDistance(pdo);
if (pdr.Status != PromptStatus.OK) return;
Point3d center = ppr.Value.TransformBy(ed.CurrentUserCoordinateSystem);
double radius = pdr.Value;
using (Transaction tr = db.TransactionManager.StartTransaction())
BlockTableRecord btr =
(BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
while (true)
using (DBPoint point = new DBPoint())
DBPointJig jig = new DBPointJig(point, center, radius);
PromptResult pr = ed.Drag(jig);
if (pr.Status != PromptStatus.OK) break;
btr.AppendEntity(point);
tr.AddNewlyCreatedDBObject(point, true);
db.TransactionManager.QueueForGraphicsFlush();
tr.Commit();
catch (System.Exception ex)
ed.WriteMessage("\nError: " + ex.Message + ex.StackTrace);
finally
db.Pdmode = pdmode;
db.Pdsize = pdsize;
ed.Regen();
class DBPointJig : EntityJig
private double radius, angle;
private Point3d center;
private DBPoint point;
public DBPointJig(DBPoint point, Point3d center, double radius)
: base(point)
this.point = point;
this.center = center;
this.radius = radius;
protected override bool Update()
point.Position = Polar(center, angle, radius);
return true;
protected override SamplerStatus Sampler(JigPrompts prompts)
JigPromptAngleOptions opt = new JigPromptAngleOptions("\nAngle: ");
opt.BasePoint = center;
opt.UseBasePoint = true;
opt.Cursor = CursorType.RubberBand;
opt.UserInputControls =
UserInputControls.UseBasePointElevation | UserInputControls.NullResponseAccepted;
PromptDoubleResult pdr = prompts.AcquireAngle(opt);
if (pdr.Status == PromptStatus.Cancel || pdr.Status == PromptStatus.Error)
return SamplerStatus.Cancel;
else if (pdr.Value == angle)
return SamplerStatus.NoChange;
else
angle = pdr.Value;
return SamplerStatus.OK;
private Point3d Polar(Point3d center, double angle, double distance)
return new Point3d(
center.X + distance * Math.Cos(this.angle),
center.Y + distance * Math.Sin(this.angle),
center.Z);
ADN Support Specialist
27 Kudos
Post 2 of 4
Re: Prompt user to pick point on circle with given radius
07-25-2013 03:05 PM in reply to: m.schilder
I like this sample project http://spiderinnet1.typepad.com/blog/2012/01/autocad-net-entityjig-jig-circle-by-center-and-radius.h...
Fenton Webb
Developer Technical Services
Autodesk Developer Network
*Expert Elite*
253 Kudos
Post 3 of 4
Re : Prompt user to pick point on circle with given radius
07-26-2013 03:59 AM in reply to: m.schilder
using System;
        public void Test()
            try
                db.Pdmode = 3;
                db.Pdsize = -3.0;
                    while (true)
                    tr.Commit();
            finally
                db.Pdmode = pdmode;
                db.Pdsize = pdsize;
                ed.Regen();
            : base(point)
            this.point = point;
            return true;
            else
                angle = pdr.Value;
            return new Point3d(
                center.Z);
Gilles Chanteau
New Member
0 Kudos
Post 4 of 4
07-29-2013 12:25 AM in reply to: m.schilder
Hi _gine,
seems to be the solution, for the moment. Thank you.
If anyone is curious how _gine's solution looks like: see the attached screenshot. The 'x' marks a point on an (imaginary) circle with pre-entered center and radius.
I have an old C++-code snippet, which (I guess) allows picking a point at specified distance with a fixed-length rubberband. Unfortunately, I'm not able to validate my assumptions, since it's an old, abandoned project which I'm not able to compile. Furthermore, I wasn't able to find any documentation on the used ads_*-functions. Maybe someone is interesed in this.
int GetPointAtDistance(ads_point base, double dDistance, ads_point retPoint, int *piKeyCode)
	int ret = 0;
	int result;
	struct resbuf ergebnis;
	double angle_old, angle;
	angle_old = 0;
	World2Ucs(base);
	ads_polar(base,0,dDistance,retPoint);
	ads_grdraw(base,retPoint,-1,0);
	do
		result = 0;
		ret = ads_grread(15,&result,&ergebnis);
		if (ret != RTNORM)
			return ret;
		switch(result)
			case 2:
				if(piKeyCode)
					*piKeyCode = ergebnis.resval.rint;
					ret = RTKWORD;
				break;
			case 5:
				angle = ads_angle(base,ergebnis.resval.rpoint);
				if (angle != angle_old)
					ads_polar(base,angle,dDistance,retPoint);
				angle_old = angle;
				break;
			case 3:
				break;
			case 12:
				ret = RTCAN;
				break;
	} while(result != 3 && ret == RTNORM);
	return ret;
Post to the Community
New Post
