.NET
.NET
Valued Contributor
3 Kudos
Post 1 of 3
Prompt message issue with a modeless dialog
386 Views, 2 Replies
09-27-2012 11:26 PM
Base: Object ARX 2010
Language: C# (.NET Frame 3.5)
I made a modeless dialog  (WinForm) to use as a toolbar. The dialog has a button that "Prompt Entity" from the drawing.
ex)
PromptEntityOptions peo = new PromptEntityOption("Select Entity:");
PromptEntityResult per = ed.GetEntity(peo);
But this function is not wokring as I intended. When I click this button, the prompt message (message that sticks on the mouse cursor) does not show up immediately.
The message appears when I click the drawing window twice.
This behavior is not good since the user would not know if the button is clicked properly. (if the prompt message does not show up immediately.)
It seems like a focus (window) issue to me.
How could I solve this issue?
Any idea?
Jake
I saw this in one other topic. Try to use Autodesk.AutoCAD.Internal.Utils.SetFocusToDwgView()
Valued Contributor
2 Kudos
Post 2 of 3
Re: Prompt message issue with a modeless dialog
09-28-2012 03:40 AM in reply to: dynamicscope
Distinguished Contributor
10 Kudos
Post 3 of 3
09-28-2012 04:48 AM in reply to: dynamicscope
There are other Methods than using the setfocus to dwg:
Look at the next snipped:
private void btnPickPoint_Click(object sender, EventArgs e)
            using (EditorUserInteraction edUsrInt = ed.StartUserInteraction(this))
                // Code to select a point
PromptPointOptions prPtOpts = new PromptPointOptions("\nSpecify insertion base point:"); PromptPointResult prPtRes = ed.GetPoint(prPtOpts); _point = prPtRes.Value; tbX.Text = _point.X.ToString(); tbY.Text = _point.Y.ToString(); tbZ.Text = _point.Z.ToString(); // End the UserInteraction. edUsrInt.End(); //this.Focus(); } }
 Hope this will help!
Irvin
