I have a pick distance button in a .net form. I add following code for the pick button clicked event:
PromptDoubleResult result = AcadAppServices.Application.DocumentManager.MdiActiveDocument.Editor.GetDistance("Specify distance:");
if (result.Status == PromptStatus.OK)
double distance = result.Value;
Here're the steps to show the problem:
Open autocad, type netload to load the .net dll. Call command to open the form, click the pick button: (form hide -> specify a distance -> form show). Then Close the form, type textscr in the command line to open AutoCAD Text Window. Click close button "X" of the Text Window, but fail.
I try not to click pick buton and then cancel the form and open the AutoCAD Text Window, the text window can be closed normally. So I doult if there's some problem with the API AcadAppServices.Application.DocumentManager.MdiActiveDocument.Editor.GetDistance().
If anyone can have a look at this problem, I really appreciate.
Thanks much
