.NET
.NET
Active Contributor
0 Kudos
Post 1 of 8
Programmatically refresh layer usage information .NET
1063 Views, 7 Replies
10-12-2010 01:03 PM
In C# I noticed that when I loop through the LayerTableRecords in the LayerTable some of the layers in the drawing do not show up.  If I look at the layers in the UI it shows the missing layers with a grey icon for their status while the ones that it does detect have a blue icon for their status.  The status has to do with which layers that the drawing believes are in use.  In the UI you can press a refresh button and this will fix the problem.  I want to know how I can fix this through the .NET API, COM API, or command line.
It seems that the problem was that one of the entities in the particular drawing was corrupt. When one of the users recreated the drawing (including re-adding some xrefs) and ran the program it worked just fine. I also double checked the code and it was definitely hitting the correct layers this time. I am however open to suggestions or solutions on how to detect corruption problems in AutoCAD drawings.
Valued Mentor
13 Kudos
Post 2 of 8
Re: Programmatically refresh layer usage information .NET
10-12-2010 01:43 PM in reply to: skeletank
Have not tested it but have you tried the LayerTable method GenerateUsageData
You can also find your answers @ TheSwamp
Active Contributor
0 Kudos
Post 3 of 8
10-13-2010 06:31 AM in reply to: Jeffrey_H
I tried calling GenerateUsageData before doing a foreach loop on the LayerTable but it still didn't return all the layers.
Active Contributor
0 Kudos
Post 4 of 8
10-13-2010 08:53 AM in reply to: skeletank
Another thing that I noticed is that this problem only occurs when I open the database using Database.ReadDwgFile.  If I first open the drawing using Application.DocumentManager.Open and then get the database from MdiActiveDocument then all of the layers show up correctly.  I would open the drawing but it is much faster to alter the database.  All that I'm doing is setting Freeze/On/Locked on the layers.
Valued Mentor
13 Kudos
Post 5 of 8
10-13-2010 10:03 AM in reply to: skeletank
Can you post your code that would help alot for helping you out.
Active Contributor
0 Kudos
Post 6 of 8
10-13-2010 10:25 AM in reply to: skeletank
The following shows two examples of enumerating through the layers.  The second option will work, but I as I said earlier I do not want to open the drawing.
Here's the code for just opening the database:
using (Database database = new Database(false, true))
          database.ReadDwgFile(drawingFilePath, FileShare.ReadWrite, true, String.Empty);
          using (Transaction transaction = database.TransactionManager.StartTransaction())
            LayerTable layerTable = transaction.GetObject(database.LayerTableId, OpenMode.ForWrite) as LayerTable;
            database.Clayer = database.LayerZero;
            foreach (ObjectId layerID in layerTable)
              LayerTableRecord layer = (LayerTableRecord)transaction.GetObject(layerID, OpenMode.ForWrite);
              //Do something to layer
            transaction.Commit();
Here's the code when opening the drawing:
Application.DocumentManager.Open(drawingFilePath, false);
      Document document = Application.DocumentManager.MdiActiveDocument;
      Database database = document.Database;
      DocumentLock documentLock = document.LockDocument(DocumentLockMode.Write, null, null, true);
      using (documentLock)
Active Contributor
0 Kudos
Post 7 of 8
10-19-2010 05:47 AM in reply to: skeletank
Active Contributor
0 Kudos
Post 8 of 8
05-13-2013 04:07 PM in reply to: skeletank
Exactly the same issue hasn't been solved in ACAD2012. I tried to Audit and recover my dwg file and found nothing corrupted. How many years needed to solve it?
