.NET
Distinguished Contributor
4 Kudos
Post 1 of 1
Programmatically Open a Drawing
165 Views, 0 Replies
06-03-2014 11:33 PM
My program reads dwg files into a side database to read information, like so:
db.ReadDwgFile(fName, FileShare.ReadWrite, false, "");
 Based on that information, the program has to open a dwg file in the Editor:
DocumentCollection dm = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager;
try
	dm.Open(fName, false);
 The problem I'm encountering is this:
If I use a modal dialog in the document context, I get "Invalid execution context" error when trying to open the file in the editor.
On the other hand, if I use a modeless dialog in the Application context, trying to read a dwg into the side database gives "eNoInputFiler" error.
I suppose this is related to the execution context, but I haven't been able to make it work.
(the xref dialog in AutoCAD succeeds though)
Any help will be much appreciated.
alex
