.NET
mgorecki
Message 1 of 7 (393 Views)
Programmatically Exiting AutoCad
393 Views, 6 Replies
01-18-2013 08:16 AM
I'm trying to update an existing program so that people can run it in a batch mode kind of way.  I want the code to run, then when the drawing is complete, the program will save the drawing and then exit AutoCad.
Is there a way to do this?  If so, how?
Mark
>> So there's no way it can be added to the end of a .NET program?
I don't know what part of your program is dotNET now.
You start AutoCAD via batch file (at least I think so when looking to how you start AutoCAD). And you start AutoCAD with a script. Where is the part you have dotNET active?
If your AutoCAD script loads a dotNET-DLL then of course, you can quit the running application using SendCommand, or using COM-interface
   Autodesk.AutoCAD.Interop.IAcadApplication ==> .Quit
or using the managed part of the API
   Autodesk.AutoCAD.ApplicationServices.Application ==> .Quit
- alfred -
Alfred.NESWADBA
Message 2 of 7 (386 Views)
Re: Programmatically Exiting AutoCad
01-18-2013 08:34 AM in reply to: mgorecki
are you just starting a process with the Processes-functionality or did you use COM to start AutoCAD?
Show us how you are connected to AutoCAD as the answer might be different depending on how you opened AutoCAD.
- alfred -
Alfred NESWADBA
mgorecki
Message 3 of 7 (380 Views)
01-18-2013 08:49 AM in reply to: Alfred.NESWADBA
Hello Alfred,
Here is the command we use:
"C:\Program Files\AutoCAD 2010\acad.exe" /b "C:\Support\PackageOutline\403142PO.scr"
It launches AutoCad and immediately executes a script file that launches either a Lisp program or a .Net program.  The script also feeds it info for the program to launch.
Mark
Alfred.NESWADBA
Message 4 of 7 (373 Views)
01-18-2013 09:14 AM in reply to: mgorecki
ok, then - on the end of your script - use the _QUIT command
- alfred -
Alfred NESWADBA
mgorecki
Message 5 of 7 (367 Views)
01-18-2013 09:48 AM in reply to: Alfred.NESWADBA
Thanks, I tried that in a test script and it worked great.
In LiSP I was able to add the save command followed by the command to quit and it worked.  So there's no way it can be added to the end of a .NET program?
Alfred.NESWADBA
Message 6 of 7 (359 Views)
01-18-2013 10:50 AM in reply to: mgorecki
- alfred -
Alfred NESWADBA
mgorecki
Message 7 of 7 (356 Views)
01-18-2013 10:59 AM in reply to: Alfred.NESWADBA
Alfred, thank you very much.  I'm goimng to go with the _quit in the script file.  That way regardless of which program (LiSP or .Net) that runs, the script will save and quit out of AutoCad without me having to update either of the programs.
Best regards,
Mark
