.NET
.NET
*Maksim Sestic
Message 1 of 9 (558 Views)
Programatically loading .NET Assemblies (no Lisp, no Registry)
558 Views, 8 Replies
09-17-2005 06:28 AM
Dear all,
Is there a way to programatically load .NET
assembly, beside executing it (netload) from Lisp
or demand-loading it via Registry setting? What ObjectARX mechanism is
hidden behind NETLOAD command? Is there any example or tip of loading .NET
assembly via P/Invoke?
I'm trying to create a clean (as possible)
startup module that fires ACAD up and loads necessary assemblies. Doing it
via .LSP module is really messy approach. Setting Registry values that
load them on-demand is a heavy task having in mind that we have
installer routine. Installer should: 1) determine ACAD version(s), 2) let the
user select one of them, 3) perform Registry settings... An
overkill.
size=2>
Maksim Sestic
*Tony Tanzillo
Message 2 of 9 (558 Views)
Re: Programatically loading .NET Assemblies (no Lisp, no Registry)
09-17-2005 01:43 PM in reply to: *Maksim Sestic
Perhaps I'm not clear on your question.
What do you mean by 'programatically load' ?
Load it programmatically from what?
E.g., from LISP code, ARX code, VBA code, etc?
You don't need to use P/Invoke to load an assembly
from managed code, which is why I"m not all that
clear on what you need to do?
Are you just trying to avoid having to do the registry
business during install?
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006
http://www.acadxtabs.com
"Maksim Sestic" wrote in message news:4959553@discussion.autodesk.com...
Dear all,
Is there a way to programatically load .NET assembly, beside executing it (netload) from Lisp or demand-loading it via Registry setting? What ObjectARX mechanism is hidden behind NETLOAD command? Is there any example or tip of loading .NET assembly via P/Invoke?
I'm trying to create a clean (as possible) startup module that fires ACAD up and loads necessary assemblies. Doing it via .LSP module is really messy approach. Setting Registry values that load them on-demand is a heavy task having in mind that we have installer routine. Installer should: 1) determine ACAD version(s), 2) let the user select one of them, 3) perform Registry settings... An overkill.
Maksim Sestic
*Maksim Sestic
Message 3 of 9 (558 Views)
09-18-2005 04:08 AM in reply to: *Maksim Sestic
Tony,
Oh, now I see :-) What an expression :-) What I really ment is loading a
.NET assembly out of external startup module also written in .NET. What I
need to achieve is:
1) User starts an .EXE (startup) module that fires up ACAD. Startup module
is written in VB.NET.
2) Startup module waits for ACAD to finish initialization
3) Startup module loads a .NET DLL assembly into ACAD
I'm trying to avoid using Lisp's (netload) in step 3). I am also trying to
avoid assembly demand-loading via registry settings during application
installation.
Maksim Sestic
"Tony Tanzillo" wrote in message
news:4959607@discussion.autodesk.com...
Dear all,
Maksim Sestic
*Maksim Sestic
Message 4 of 9 (558 Views)
09-18-2005 04:19 AM in reply to: *Maksim Sestic
I guess it has something to do with Reflection... but I'm not completely
clear about that :-)
Dear all,
Maksim Sestic
*Maksim Sestic
Message 5 of 9 (559 Views)
09-19-2005 01:34 AM in reply to: *Maksim Sestic
Let me explain the problem a bit more
precise:
I need to load .NET DLL into
running ACAD application namespace, but externally - out of another process
(Startup module, source excerpt below). How possibly can I get it
working?
Startup module (that fires ACAD up) references
following libs found in GAC:
- Autodesk.AutoCAD.Interop.dll
Autodesk.AutoCAD.Interop.Common.dll
size=2>
size=2>Imports
''' Startup
size=2>Module
Startup
Sub
Main()
color=#008080>''' Start ACAD the easy way... No error
checking...
size=2>    Dim
oACAD
color=#0000ff size=2>As
Autodesk.AutoCAD.Interop.AcadApplication
    oACAD =
New
color=#008080>''' >>> I simply don't want to load assembly
via Lisp here.
>>> I've been thinking of using P/Invoke, still don't know what
set of
acad.exe functions is responsible for netload-ing an assembly.
Using a bit more managed approach is even more welcome
oACAD.ActiveDocument.SendCommand( _
    "(command "
+ Chr(34) + _
    "NETLOAD" +
Chr(34) + " " + Chr(34) + _
"TCGDotNet16.dll" + Chr(34) + ")" + vbLf)
End
size=2>Sub
color=#0000ff size=2>End
color=#0000ff size=2>Module
color=#0000ff size=2>Thanks for any
suggestion on that matter.
color=#000000>Regards,
color=#0000ff size=2>Maksim
Sestic
*Maksim Sestic
Message 6 of 9 (559 Views)
09-20-2005 08:21 AM in reply to: *Maksim Sestic
It seems like me talking to myself... Anyway,
after many hours of browsing the docs/internet it turns
out that I need to write a plug-in assembly that gets initialized
within AutoCAD application namespace, out of external process. Am I wrong about
that presumption?
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
precise:
working?
size=2>
size=2>Imports
color=#008080>''' Startup module that fires up
ACAD
size=2>Module
Startup
Sub
Main()
checking...
size=2>    Dim
oACAD
    oACAD =
New
via Lisp here.
set of
assembly.
    "(command
" + Chr(34) + _
    "NETLOAD"
+ Chr(34) + " " + Chr(34) + _
End
size=2>Sub
Sestic
Active Contributor
karenina
Message 7 of 9 (558 Views)
03-21-2006 07:23 AM in reply to: *Maksim Sestic
Hello.
Did you manage to solve that problem? I am having almost the same one. I am trying to write a plugin for AutoCAD 2006 that is supposed to add a new toolbar (in .NET C#).
I am having difficulties at loading my assembly to AutoCAD. Last year I wrote some plugin for AutoCAD2005, but the connection part was written in C++. I was creating an arx file and then load set the AutoCAD start in to the arx path.
I didn't like the solution then, but I was short on time so I had no choice.
So ... did you find anything on loading a .NET dll to AutoCAD?
You said something about registry ... can you be more specific?
Thank you for your time,
Roxana.
*Maksim Sestic
Message 8 of 9 (558 Views)
03-25-2006 04:44 AM in reply to: *Maksim Sestic
Hi Roxana,
Yes, autoloading managed modules on startup (via Registry setting) was the
only viable solution. Just check the following link:
http://discussion.autodesk.com/thread.jspa?messageID=4531456
Maksim Sestic
wrote in message news:5116709@discussion.autodesk.com...
Hello.
the arx path.
Roxana.
Active Contributor
karenina
Message 9 of 9 (558 Views)
03-25-2006 05:27 AM in reply to: *Maksim Sestic
Thanks a lot. That really helped.
I did not know that it was possible to set a dll as loader.
Now it works fine.
All my best,
Roxana
