.NET
.NET
0 Kudos
Post 1 of 6
problme with saveAs(), current document
409 Views, 5 Replies
05-16-2013 11:49 PM
I have a little problem, I am working with visual studio 2010 and autocad 2013, when I make a new command that save the current work(.dwg), I must use Save.As(....) because the Save() function doesnt work. When I use the SaveAs(..) method, the file is saved correcty in the path(C:\temp, for example),but (here is the problem) the current .dwg that I have in autocad is named "drawing1.dwg",and I will that when I "SaveAs()" a file, the file that shows autocad is the saved file(the new name of the file must appear in the title of the autocad document)... I know its hard to explain...
I have attached 3 picture to try to explain it better
Thank you very much.
The save method is only for use in RealDWG applications - it will not work in AutoCAD.
There are three Database.SaveAs() methods.  If you use this one:
Autodesk.AutoCAD.DatabaseServices.Database.SaveAs(string, bool, Autodesk.AutoCAD.DatabaseServices.DwgVersion, Autodesk.AutoCAD.DatabaseServices.SecurityParameters)
and pass in true for the bool second argument, then it should change the name of the document in the Acad titlebar.
I have solved my problem using this:
db.SaveAs(path,true, DwgVersion.Current, null);
thank for all the answears.
Valued Contributor
6 Kudos
Post 2 of 6
Re: problme with saveAs(), current document
05-17-2013 02:44 AM in reply to: Sined99
Instead of doing a "SaveAs", you could do a "WBlock":
Database newDB = HostApplicationServices.WorkingDatabase.Wblock();
newDB.SaveAs(...);
Luis Alberto Manero, Geograma.com
Valued Contributor
2 Kudos
Post 3 of 6
05-17-2013 02:52 AM in reply to: Sined99
"drawing1.dwg" is still the active document, in order to work with newly created "c:/temp/test.dwg" you can open it with:
Application.DocumentManager.Open(newDwg, false);
Can you show us part of your code, what's the reason that Document.Save() method does not work?
Employee
63 Kudos
Post 4 of 6
05-17-2013 05:33 AM in reply to: Sined99
0 Kudos
Post 5 of 6
05-19-2013 11:44 PM in reply to: Sined99
Thanks for the answears!, but it doesnt works... if I try to open the saved file it throws an exception (attached picture). When I try the saveAs method with the 4 parameters the compiler says that is an obsolete method. I am working with autocad 2013 and visual studio 2010.
My code:
Guardar guardar;[CommandMethod("SaveAsEsquema", CommandFlags.Session)]
public void SaveActiveDrawing()
            guardar =new Guardar();
            Autodesk.AutoCAD.ApplicationServices.Application.ShowModalDialog(guardar);
privatevoid bt_Click(object sender, EventArgs e)
Document acDoc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
Database db = acDoc.Database;
string path = "C:\\Trabajo\\DWG\\TEST.dwg";
object obj = Autodesk.AutoCAD.ApplicationServices.Application.GetSystemVariable("DWGTITLED");
db.SaveAs(path,DwgVersion.Current......
0 Kudos
Post 6 of 6
05-20-2013 05:34 AM in reply to: Sined99
