.NET
Problems with Layer Description
4 REPLIES 4
martinduke2653
1197 Views, 4 Replies
Hello All,
I am using AutoCAD 2006 and Visual Studio 2005 with VB.Net. I have a subroutine to create a layer, it works fine except that for some reason the description field does not work. Whatever value I pass in on description it fails to be applied to the layer, here is my code:
Public Sub MakeLayer(ByVal LayerName As String, ByVal Colour As Int16, _
ByVal LineType As String, Optional ByVal Description As String = "")
Dim layerId As ObjectId 'the return value for this function
Dim db As Database = HostApplicationServices.WorkingDatabase
Dim trans As Transaction = db.TransactionManager.StartTransaction()
'Get the layer table first...
Try
Dim lt As LayerTable = trans.GetObject(db.LayerTableId, OpenMode.ForWrite)
'Check if Layer exists...
If lt.Has(LayerName) Then
layerId = lt.Item(LayerName)
Else
'If not, create the layer here.
Dim ltr As LayerTableRecord = New LayerTableRecord()
ltr.Name = LayerName
ltr.Color = Color.FromColorIndex(ColorMethod.ByAci, Colour)
If LineType <> "Continuous" Then
ltr.LinetypeObjectId = CheckForLineType(LineType)
End If
ltr.Description = Description
layerId = lt.Add(ltr)
trans.AddNewlyCreatedDBObject(ltr, True)
End If
trans.Commit()
Catch aex As Autodesk.AutoCAD.Runtime.Exception
MsgBox("AutoCAD Exception (MAKELAYER): " & aex.Message, MsgBoxStyle.Exclamation)
Catch ex As System.Exception
MsgBox("System Exception: " & ex.Message, MsgBoxStyle.Exclamation)
Finally
trans.Dispose()
End Try
End Sub
Can anybody please explain what is going on here, thanks in advance for any advice you can offer.
Kind Regards,
Martin.
4 REPLIES 4
in reply to: martinduke2653
Try this instead.
_
Try
OpenMode.ForWrite)
Else
'If LineType <> "Continuous" Then
' ltr.LinetypeObjectId = CheckForLineType(LineType)
'End If
'ltr.Description = Description
End If
trans.Commit()
LayerDescription(LayerName, Description)
Finally
trans.Dispose()
End Try
End Sub
Public Sub LayerDescription(ByVal layerName As String, ByVal
Description
As String)
Using db As AcDb.Database = HostApplicationServices.WorkingDatabase
Using tr As AcDb.Transaction =
Try
Dim tbl As AcDb.LayerTable = _
CType(tr.GetObject(db.LayerTableId,
AcDb.OpenMode.ForRead,
False), AcDb.LayerTable)
If tbl.Has(layerName) Then
Dim ltr As AcDb.LayerTableRecord =
tr.GetObject(tbl.Item(layerName), AcDb.OpenMode.ForWrite, False)
End If
tr.Commit()
Catch ex As Exception
tr.Abort()
End Try
End Using
End Using
End Sub
tp
escreveu na mensagem news:5446186@discussion.autodesk.com...
Hello All,
the
it
_
Try
OpenMode.ForWrite)
Else
Colour)
End If
End If
trans.Commit()
Finally
trans.Dispose()
End Try
End Sub
any
Kind Regards,
Martin.
I'm protected by SpamBrave
http://www.spambrave.com/
Thank you for that, it works a treat, it seems to be a bit of a bug in the API to me that you cannot set the value when you first create the layer.
Martin.
GTVic
This is old but I thought I would update it. You can avoid the separate subroutine if you set the description one step later.
So instead of:
LayerObj.Description = Description
LayerTable.Add(LayerObj)
Just flip the order of those two lines:
I believe this is because the description is not really part of the layer, it is attached to the layer table or xdata or something. Therefore the description cannot be set until the layer is part of the layer table. Another side effect of this is that if you use the -EXPORTTOAUTOCAD command you will lose all of your layer descriptions.
Ajilal.Vijayan
in reply to: GTVic
Today this helped me!!!!
Thanks GTVic
”Boost
