.NET
Problem with VS2008 & autocad
1 REPLY 1
cokhitp
348 Views, 1 Reply
Hello to everybody.
I have tried to write a code that can update attribute data in block of autocad file.
I found alot of example in this forum, but i dont know why my programe can not work.
My PC is winXP, VS2008, autocad2009.
1. This code is work ofcouse:
    Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
        MsgBox("hello")
    End Sub
2. But this one does not work:
        MsgBox("hello")
        Dim myBT As DatabaseServices.BlockTable
    End Sub
As long as i insert in the code which relative to reference .dll; i got error: "The specified module could not be found. (Exception from HRESULT: 0x8007007E)"
It means that problem is my PC sysem, sofware... not about the code.
Please help me to fix it, i spent two but still not found the reason.
Here the code i used:
 Function PopulateOIDCs(ByVal BlockName As String) _
As DatabaseServices.ObjectIdCollection
        Dim myBTR As DatabaseServices.BlockTableRecord
        Dim myBTRE As DatabaseServices.SymbolTableEnumerator
        Dim myDB As DatabaseServices.Database
        Dim myTransMan As DatabaseServices.TransactionManager
        Dim myTrans As DatabaseServices.Transaction
        Dim myOIDs As New DatabaseServices.ObjectIdCollection
        Dim myOIDs2 As DatabaseServices.ObjectIdCollection
        Dim I As Long
        Dim acDoc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
        myDB = acDoc.Database
        myTransMan = myDB.TransactionManager
        myTrans = myTransMan.StartTransaction
        myBT = myDB.BlockTableId.GetObject(DatabaseServices.OpenMode.ForRead)
        myBTR = myBT(BlockName).GetObject(DatabaseServices.OpenMode.ForRead)
        myOIDs2 = myBTR.GetBlockReferenceIds(True, False)
        For I = 1 To myOIDs2.Count
            myOIDs.Add(myOIDs2.Item(I - 1))
        Next
        myBTRE = myBT.GetEnumerator
        While myBTRE.MoveNext
            myBTR = myBTRE.Current.GetObject(DatabaseServices.OpenMode.ForRead)
            If myBTR.IsLayout = False Then
                Select Case myBTR.IsAnonymous
                    Case True
                        If myOIDs2.Count > 0 Then
                            Dim myBRef As DatabaseServices.BlockReference
                            myBRef = myOIDs2(0).GetObject(DatabaseServices.OpenMode.ForRead)
                            Dim myBTR2 As DatabaseServices.BlockTableRecord
                            myBTR2 = myBRef.DynamicBlockTableRecord.GetObject( _
                            If myBTR2.Name.CompareTo(BlockName) = 0 Then
                                Next
                End Select
        End While
        myTrans.Dispose()
        myTransMan.Dispose()
        Return myOIDs
    End Function
1 REPLY 1
Balaji_Ram
in reply to: cokhitp
Is that a compile error ?
Have you set the right .Net framework version in your project settings ?
For .Net applications, you can use VS 2008 but need to set the target framework to 3.0
Balaji
Developer Technical Services
Autodesk Developer Network
”Boost
