.NET
.NET
0 Kudos
Post 1 of 2
Problem with Try block and Transaction
160 Views, 1 Replies
02-07-2012 04:13 PM
I have a VB.NET program which is very similar to another which functions fine.  In the troubled program when I enable a Try Catch block right after starting a transaction it invariably throws a Unhandeled Access Violation right at the transaction phrase.  If I remove the Try/Catch and replace it with an OnError Resume Next it completes execution but does not do what it is supposed to (extract four drawing border attribute values)
I have checked the sequence against the program which functions and other than the troubled program being in ACAD2012 and VS 2010 they are pretty much identical (Resources, database access etc... )
Any help or suggestions appreciated.
CODE FOLLOWS:
Note: DB established as: Dim db As Autodesk.AutoCAD.DatabaseServices.Database = SelectDatabase(f, False)
(and then through selectdatabase): db.ReadDwgFile(fullname,FileOpenMode.OpenForReadAndAllShare, True, Nothing)
' Used in LoadAttributesFromDrawingIntoXML
Function GetAttributes(ByVal db AsDatabase, ByVal filepath AsString) AsCollection
     Dim collection AsNewCollection
     Dim flag AsBoolean = False'
     Dim tr AsTransaction= db.TransactionManager.StartTransaction
     Try                ' - I enable the try and I get an unhandeled access violation. . .
     Dim id AsObjectId, bt AsBlockTable = tr.GetObject(db.BlockTableId, OpenMode.ForRead)
     ForEach btrID AsObjectIdInbt
             Dim btr AsBlockTableRecord = tr.GetObject(btrID, OpenMode.ForRead)
            acadEd.WriteMessage(" Btr name: "& btr.Name.ToString)
     If btr.IsLayout Then
       Dim l AsLayout = tr.GetObject(btr.LayoutId, OpenMode.ForRead)
              Dim LayoutArr AsLayoutInfo = NothingForEach id Inbtr
              Dim entity AsEntity = TryCast(tr.GetObject(id, OpenMode.ForRead), Entity)
              If (Not entity IsNothing) Then If TypeOf entity IsBlockReferenceThen
                     Dim br AsBlockReference = TryCast(entity, BlockReference)
              Dim borderNames = (From all In GetXelementFromCollection("BORDERINFO").Elements
                              Select all.<NAME>.Value.ToUpper).Distinct
               If (From all In GetXelementFromCollection("BORDERINFO").Elements Where
                 all.<NAME>.Value.ToUpper = br.Name.ToUpper Select all).Count > 0 Then
                     Dim attributeCollection As _
                     Autodesk.AutoCAD.DatabaseServices.AttributeCollection=
                     br.AttributeCollection
                      Dim IsValid AsBoolean = False
Dim UniqueBlockName AsString = ""Dim BlkArr AsNewBlockInfo(br.Name,
                     IsValid, UniqueBlockName, br.Handle.Value)
                     ForEach atID AsObjectIdInattributeCollection
                                  Dim atRef AsAttributeReference = atID.GetObject(OpenMode.ForRead)
                                  Dim atInfo AsNewAttributeInfo
                              WithatInfo
                                  ._Tag = atRef.Tag
                                      ._Text = atRef.TextString
                                      ._ObjectID = atRef.ObjectId.OldIdPtr.ToInt64
                                      ._BlockName = br.Name
                                      ._HandleValue = atRef.ObjectId.Handle.Value
                                  EndWith
                              BlkArr.Add(atInfo)
                           Next
If LayoutArr IsNothingThen
LayoutArr = NewLayoutInfo(l.LayoutName)
                                  LayoutArr.Add(BlkArr)
                     Else
                           EndIf
                EndIf
           EndIf
       EndIf
  Next               'id'--add layout collections
  If Not LayoutArr IsNothingThen collection.Add(LayoutArr)
EndIf'islayout
Next'btr
Catch ex As System.Exception
tr.Abort()
System.Windows.Forms.
MessageBox.Show("Error in (GetAttributes)") ' & vbCr & ex.Message, "Error occured")
db.Dispose()
Finally
tr.Dispose()
db.Dispose()
EndTry
Return collection
EndFunction
1,218 Kudos
Post 2 of 2
Re: Problem with Try block and Transaction
02-12-2012 12:33 PM in reply to: CADKarasu
what I see is you do the db.Dispose twice in case you fall into the catch-block.
What I don't see:
  • what error (exact error message) do you get
  • at what line does your debugger interrupt because of exception (I don't understand what you mean by "throws a Unhandeled Access Violation right at the transaction phrase" as I don't know what is the line with the "transaction phrase")
- alfred -
PS: please use this button
to transmit code to the message-text, this will avoid the deleting of a lot of spaces that makes it impossible to try your code without doing a lot of corrections.
Alfred NESWADBA
