Hello, I've been experiencing the following problem:
I've created a PaletteSet with a UserControl. The control contains a lot of image buttons, so I added a Tooltip control to the UserControl and associated every button with a tooltip. Everything works perfectly, except for a very strange behavior of the command line window (F2). The window behaves normally after the application is loaded and the custom palette is displayed, however if a move the mouse pointer over any of my buttons and a tooltip is displayed, the command line window no longer displays correctly. When pressing F2 to show the command line window, it just flickers and stays minimized. It just keeps doing it until I restart AutoCAD.
Does anybody have a solution for this? I've tested the application in AutoCAD 2008, 2009 (x86 & x64), 2010 (x86 & x64) with the same results. However, if a change the minimum size of my UserControl to 300,400, the problem disappears and everything works flawlessly. Any smaller size causes the problem.
Any advise is appreciated.
