.NET
.NET
Active Contributor
ZK_BUDiKOM
Message 11 of 25 (773 Views)
Re: Problem with PaletteSet location in Autocad
11-19-2012 05:51 AM in reply to: Alfred.NESWADBA
  • you have set the property "local copy" for the references to "yes" ==> that should be "no"
Where is this position?
  • how do you debug your project? When going to project-properties you have not set the "external program to start" to your ACAD.EXE or to the ACCORECONSOLE.EXE.
OK.
I've added acad.exe.
After Debug (F5), AutoCAD2013 run and show me the error message:
Application does not support just-in-time (JIT)
debugging. See the end of this message for details.
************** Exception Text **************
System.InvalidCastException: Unable to cast object of type 'Autodesk.AutoCAD.LivePreview.PreviewRuleProvider' to type 'Autodesk.AutoCAD.Internal.IPreviewContextProvider'.
at Autodesk.AutoCAD.LivePreview.PreviewContextService.LoadContext()
at Autodesk.AutoCAD.LivePreview.PreviewContextService.get_ContextProvider()
at Autodesk.AutoCAD.LivePreview.PreviewContextManager.OnIdleInitialize(Object sender, EventArgs e)
at System.EventHandler.Invoke(Object sender, EventArgs e)
at Autodesk.AutoCAD.ApplicationServices.Core.Application.OnIdle()
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.0.30319.296 (RTMGDR.030319-2900)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
Acdbmgd
Assembly Version: 19.0.0.0
Win32 Version: 19.0.55.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202013/AcdbMgd.DLL
System
Win32 Version: 4.0.30319.296 built by: RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Core
I load my DLL (netload) and write PREV.
I see My Palette.
I write LDPRV, and error.
regards
Active Contributor
ZK_BUDiKOM
Message 12 of 25 (765 Views)
11-19-2012 06:08 AM in reply to: ZK_BUDiKOM
OK. I have found this "local copy".
I changed to "False".
Now, F5 (Debbug) doesn't generate an error, but still is when I write LDPRV.
Alfred.NESWADBA
Message 13 of 25 (752 Views)
11-19-2012 09:29 AM in reply to: ZK_BUDiKOM
Ok, then next step is to tell the debugger to stop on all errors. Do that in Visual-Studio ==> pull-down-menu "debug" ==> item "exceptions" (hope that the translation from my German version is ok for that words) and within this dialog check "Common Language Runtime Exceptions".
Now exceptions raised during code will break the debugger and show you the position where the exception occured.
- alfred -
Alfred NESWADBA
Active Contributor
ZK_BUDiKOM
Message 14 of 25 (740 Views)
11-19-2012 11:33 PM in reply to: Alfred.NESWADBA
It's done.
I have found description this exception:
http://msdn.microsoft.com/query/dev10.query?appId=Dev10IDEF1&l=EN-US&k=k(EHNULLREFERENCE);k(TargetFr...
Do you have any idea what now?
regards
Alfred.NESWADBA
Message 15 of 25 (736 Views)
11-20-2012 12:12 AM in reply to: ZK_BUDiKOM
myPreviewBox is never set to an object (never instanciated) as this.Preview is never started.
- alfred -
Alfred NESWADBA
Active Contributor
ZK_BUDiKOM
Message 16 of 25 (733 Views)
11-20-2012 12:35 AM in reply to: Alfred.NESWADBA
Hmm...
in an example was:
/// <summary>
/// Instance of the Preview box
/// </summary>
PreviewBox myPreviewBox;
I have changed to:
PreviewBox myPreviewBox = new PreviewBox();
and now, the error is here:
maybe this example is incorrect and I never won't run this project?...
regards
Alfred.NESWADBA
Message 17 of 25 (730 Views)
11-20-2012 12:44 AM in reply to: ZK_BUDiKOM
does that happen with all drawings? Have you set your AutoCAD to "not save the thumbnails"?
The error seems to raise when the line above does not return a valid object (variable preview). So either there is no image in the file or the function does not return a bitmap.
(have not tried your code, so that's just guessing)
- alfred -
Alfred NESWADBA
Active Contributor
ZK_BUDiKOM
Message 18 of 25 (729 Views)
11-20-2012 12:49 AM in reply to: ZK_BUDiKOM
When I comment this line:
//grab the thumbnail bitmap and get rid of the white background
System.Drawing.Bitmap preview = dbb.ThumbnailBitmap;
//preview.MakeTransparent(System.Drawing.Color.White);
program run propertly, but view nothing in "My Palette"...
I added Alert in this place:
Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog("\nAlert " + fn.StringResult);
//use the loaded dwg file to update the preview box
myPreviewBox.load_file_preview(fn.StringResult);
and show me path to my DWG file - is correct, eg. "c:\Blocks\My_blok.dwg".
"does that happen with all drawings?" - Yes.
Have you set your AutoCAD to "not save the thumbnails"? - where can I set this?
regards
Alfred.NESWADBA
Message 19 of 25 (727 Views)
11-20-2012 12:57 AM in reply to: ZK_BUDiKOM
Command _OPTIONS ==> tab "Open and Save" ==> button "Thumbnail Preview Settings"
- alfred -
Alfred NESWADBA
Active Contributor
ZK_BUDiKOM
Message 20 of 25 (724 Views)
11-20-2012 01:01 AM in reply to: Alfred.NESWADBA
I have the same like you :smileyhappy:
regards
