Hi all,
I have a problem with calling a property Surface of Autodesk.AutoCAD.BoundaryRepresentation.Face object. Sometimes, an instance of Autocad falls down, when I call the procedure that is written bellow more than one time – the more complex the model is the sooner it occurs (number of successful attempts varies from 1 to 6-7).
I can’t find out why the problem occurs. I would really appreciate any help.
Here’s the code I’m using:
Transaction tr = Application.DocumentManager.MdiActiveDocument.Database.TransactionManager.StartTransaction();
try
BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
BlockTableRecord btr = (BlockTableRecord)tr.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForRead);
foreach (ObjectId id in btr)
DBObject obj = tr.GetObject(id, OpenMode.ForRead);
System.Type objType = obj.GetType();
if (objType.ToString() == "Autodesk.AutoCAD.DatabaseServices.Solid3d")
ObjectId[] objIds = { obj.ObjectId };
Solid3d sol = (Solid3d)obj;
Brep brp = new Brep(sol);
foreach (Complex cmplx in brp.Complexes)
foreach (Shell shll in cmplx.Shells)
foreach (Autodesk.AutoCAD.BoundaryRepresentation.Face fce in shll.Faces)
ExternalBoundedSurface bSurface = fce.Surface as ExternalBoundedSurface;
Type entType = bSurface.ExternalBaseSurface.nativeSurface.GetType();
tr.Commit();
catch (System.Exception ex)
tr.Abort();
finally
tr.Dispose();
