.NET
Problem with GetString
10 REPLIES 10
Message 1 of 11
474 Views, 10 Replies
I wanted to ask for some stings, in this case for a prefix and a suffix.
I do it with something like the following code
PromptStringOptions optString = new PromptStringOptions("\nPrefix");
optString.AllowSpaces = true;
PromptResult prString = ed.GetString(optString);
If I write "km " or " km" for the string, it allways returns "km" without
the spaces.
Is it possible to get these spaces, too?
Roland
10 REPLIES 10
Message 2 of 11
Realy strange, your code works
for me in A2007
~'J'~
public class StringUtils
[CommandMethod("CTX")]
public static void SpaceText()
Document doc = acadApp.DocumentManager.MdiActiveDocument;
Editor ed = doc.Editor;
string s = "1000";
PromptStringOptions optString = new PromptStringOptions("\nPrefix: ");
string p = prString.StringResult;
MessageBox.Show(string.Format("Result: {0}", s + p));
Message 3 of 11
Thank you, Fatty.
I work with 2008, and there I get the wrong result. With your example when i
type " km" the MessageBox shows: "Result: 1000km" and not "Result: 1000 km".
Very strange. Does anyone have the same problem?
Roland
schrieb im Newsbeitrag news:5633520@discussion.autodesk.com...
for me in A2007
~'J'~
string s = "1000";
Message 4 of 11
Hi Fatty,
I tried it now in 2007 and it also doesn't work there.
Does it really work correct for you?
Roland
Message 5 of 11
Hi Roland, yes it does work nice
But in fact I use VB.NET, I just converted
my code for you
tested on A2007 only
Here is it
_
Public Shared Sub SpaceText()
Dim doc As Document = acadApp.DocumentManager.MdiActiveDocument
Dim ed As Editor = doc.Editor
Dim s As String = "1000"
Dim optString As PromptStringOptions = New PromptStringOptions(vbcr & "Prefix: ")
optString.AllowSpaces = True
Dim prString As PromptResult = ed.GetString(optString)
Dim p As String = prString.StringResult
MessageBox.Show(String.Format("Result: {0}", s & p))
End Sub
~'J'~
Message 6 of 11
This works also with suffix and prefix
See picture
_
Dim optString As PromptStringOptions = New PromptStringOptions("\nPrefix")
MessageBox.Show(String.Format("Result: {0}", p & s))
End Sub
~'J'~
Message 7 of 11
Thank you, again, Fatty.
So this seems to be a bug in C#.
Roland
Message 8 of 11
Luis Esquivel
It is working here using A2007
[code]
[CommandMethod("OTXT")]
public void otxt()
ed.WriteMessage("\nReturn: 1000" + prString.StringResult);
[/code]
Message 9 of 11
Thank you, Luis.
Your code also didn't work for me with 2007. Therefore I wanted to make a
screenshot of the text-window and saw that the input had no spaces allthough
I typed them in. Then I tried this command with opened text-window and it
worked. So the problem is not the command, it is AutoCAD. I use the dynamic
input, and with this it does not work.
Am I right that no one of you does work with dynamic input and therefore you
had no problems? I think so.
Roland
Message 10 of 11
Hi Roland;
Yes I use the dyn-input too, but did not tested with that, last night, I'll
check a little later, and post the result here 🙂
>>you had no problems? I think so.
Message 11 of 11
OK;
You are right, it is NOT working. - Another BUG they will say.... 🙂
>>I'll check a little later, and post the result here 🙂
”Boost
