.NET
Problem with editing attributes in a block
2 REPLIES 2
546 Views, 2 Replies
I'm trying to edit the attributes in a titleblock using VB.net. The block name is "Titleblock". It is already inserted into a drawing. My program does not need to insert it. It only needs to find the reference, for all layouts, and update a couple attributes for the titleblock on everylayout. I know some of the basics, but get confused with blocktables, and blocktablerecords.
Here is a piece of code I was experimenting with. With this code, I'm trying to get to the attributes, and read an attribute value for a drawing number.  It fails when I try to assign a value to the variable blkreftitle. Any help and suggestions would be greatly appreciated.
Dim
doc AsDocument = Application.DocumentManager.MdiActiveDocument
Using docLoc AsDocumentLock = doc.LockDocument
Dim db AsDatabase = HostApplicationServices.WorkingDatabase
Using tr AsTransaction = db.TransactionManager.StartTransaction
Dim bt AsBlockTable = db.BlockTableId.GetObject(OpenMode.ForRead)
Dim blID AsObjectId = bt("TITLEBLOCK")
Dim blkRefTitle AsBlockReference = blID.GetObject(OpenMode.ForRead)
Dim myAttColl AsAttributeCollection = blkRefTitle.AttributeCollection
ForEach myAttRefId AsObjectIdIn myAttColl
Dim myAttRef AsAttributeReference = myAttRefId.GetObject(OpenMode.ForWrite)
If myAttRef.Tag = "DWGNUM"Then
                        strDwgNum = myAttRef.TextString
                        MsgBox(strDwgNum)
EndIf
Next
                tr.Commit()
EndUsing
EndUsing
2 REPLIES 2
adadnet
hi
firstly, i think that although the block table does contain blocktablerecords and block definitions (and block attribute definitions), the starting point should be the former so that:
"Dim blkRefTitle AsBlockReference = blID.GetObject(OpenMode.ForRead)" should read
Dim blkRefTitle AsBlockTableRecord = blID.GetObject(OpenMode.ForRead), i.e. access any specificly named blocktablerecord via its 'parent' blocktable.
secondly, a blocktablerecord may or may not then contain blockreferences (derived from the blockdefinition in the blocktable), so only when you find the respective blockreference in its 'parent' blocktablerecord you can access it as such. (i would think the same applies to block attributes: attdefs are kept in the bt and attrefs are appended to the blockref's attcol.)
this is new to me too, but hope this helps.
felix
Hallex
Your main mistake is you don't understand difference between BlockReference
and BlockTableRecord
See nice explanation about this in the post#2 by Norman Yuan from this thread:
http://forums.autodesk.com/t5/NET/Check-is-AttributeReference-instance-of-concrete/m-p/2709253/highl...
secondly, this line of your code:
just read attribute value but do not change it
and also if you want to change just one item within the
For Each....Next statement, you have to use Exit For right after
you reach at desired item to avoid infinite or extafluous  loop, something like
For Each obj as AnyType in SomeCollection
If obj.SomeProperty=ExactValue Then
obj.OtherPrperty=OtherExactValue
Exit For
Next
hope that helps
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
”Boost
