i want to attach template on my drawing through c# code, can any one help me how to do this.
You can use http://www.theswamp.org/index.php?topic=44313.0
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.ApplicationServices
Imports System.IO
Public Class Class2
<CommandMethod("AddtoBT")> _
Public Sub InsBlock()
Dim FileNameLoc As String = "C:\TEMP\CIRCLESQUARE.DWG"
Dim FileName As String = "CIRCLESQUARE"
Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
Dim db As Database = doc.Database
Dim xDB As New Database(False, True)
xDB.ReadDwgFile(FileNameLoc, FileShare.Read, True, Nothing)
Using tr As Transaction = doc.TransactionManager.StartTransaction()
Dim bt As BlockTable = DirectCast(tr.GetObject(db.BlockTableId, OpenMode.ForWrite), BlockTable)
Dim id As ObjectId = db.Insert(FileName, xDB, True)
tr.Commit()
End Using
End Sub
