.NET
Problem with copied/pasted blocks when try to purge it
2 REPLIES 2
OCODER
255 Views, 2 Replies
Hi All;
I am using below code to count number of blocks in my drawing, it works well, but there is a problem when i copy/paste a block.
For example, if i found that there are 7 blocks from block (A), then went back to my drawing and copied/pasted one block from this type (A), the result is 8 blocks.
it is good..
but when i delete this copied/pasted one and run the code again, it also gives me 8 blocks.
Important note: Purge command can solve this problem, but from autocad directly.
I tried some codes to purge this copied/pasted block, but there is no success up to now.
Any help please.
Thank for all in advance
 <CommandMethod("BOQBlockCounter")> _
Public Sub BOQBlockCounter(ByVal myGrid As DataGridView)
        Dim myDB As Database = HostApplicationServices.WorkingDatabase
        Dim curRow As Integer = 0
        Using myTrans As Transaction = myDB.TransactionManager.StartTransaction
            Dim myBT As BlockTable = myDB.BlockTableId.GetObject(OpenMode.ForRead)
            For Each myBTRid As ObjectId In myBT
                Dim myBTR As BlockTableRecord = myBTRid.GetObject(OpenMode.ForRead)
                'Dim parentName As String = ""
                'MsgBox(myBTR.Name & vbTab & myBTR.GetBlockReferenceIds(True, True).Count)
                If myBTR.Name = "*Model_Space" Or myBTR.Name = "*Paper_Space" Or myBTR.Name = "*Paper_Space0" Then
                    ' Do Nothing
                Else
                    If myBTR.GetBlockReferenceIds(True, True).Count > 0 Then
                        myGrid.Rows.Add()
                        myGrid.Item(0, curRow).Value = myGrid.Rows.Count
                        myGrid.Item(1, curRow).Value = myBTR.Name
                        myGrid.Item(2, curRow).Value = myBTR.GetBlockReferenceIds(True, True).Count
                        curRow += 1
            Next
            myTrans.Abort()
            'myExcel = Nothing
        End Using
    End Sub
2 REPLIES 2
mcicognani
in reply to: OCODER
The BlockReference list contains also erased references. Usually I check the entities ObjectIds making a call to GetObject(id, true) and checking the IsErased property.
Note the second parameter to True, to allow for reading erased objects.
norman.yuan
in reply to: mcicognani
BlockReference list returned froom BlockTableRecord.GetBlockReferenceIds() DOES NOT include ObjectIds of erased BlockReference, according to the ObjectARX document on this method:
<QUOTE>
This function returns a list of BlockReferences that either directly or indirectly, through block nesting, reference this block. It only returns those block references that are currently active. Use getErasedBlockReferenceIds() to get a list of erased references.
<QUOTE>
Following code shows this:
    public class MyCadCommands
        private static string _blkName = "MyTestBlock";
        // Open a drawing that has a few block "MyTestBlock" inserted
        // Run this command before and after erase several block references
        [CommandMethod("BlkCount")]
        public static void GetBlkCount()
            Document dwg = CadApp.DocumentManager.MdiActiveDocument;
            Editor ed = dwg.Editor;
            try
                ObjectIdCollection activeIds;
                ObjectIdCollection erasedIds;
                GetBlockCount(
                    dwg.Database, _blkName, out activeIds, out erasedIds);
                ed.WriteMessage(
                    "\nActive Block Reference Count: {0}", activeIds.Count);
                ed.WriteMessage(
                    "\nErased Block Reference Count: {0}", erasedIds.Count);
            catch (System.Exception ex)
                ed.WriteMessage("\nError: {0}\n{1}", ex.Message, ex.StackTrace);
            finally
                Autodesk.AutoCAD.Internal.Utils.PostCommandPrompt();
        private static void GetBlockCount(
            Database db, string blkName,
            out ObjectIdCollection activeIds,
            out ObjectIdCollection erasedIds)
            activeIds = null;
            erasedIds = null;
            using (Transaction tran=db.TransactionManager.StartTransaction())
                BlockTable bt = (BlockTable)tran.GetObject(
                    db.BlockTableId, OpenMode.ForRead);
                if (bt.Has(blkName))
                    BlockTableRecord br = (BlockTableRecord)
                        tran.GetObject(bt[blkName], OpenMode.ForRead);
                    activeIds = br.GetBlockReferenceIds(true, true);
                    erasedIds = br.GetErasedBlockReferenceIds();
                tran.Commit();
Norman Yuan
Drive CAD With Code
”Boost
