.NET
Problem with Application.DocumentManager.Open?
2 REPLIES 2
RasmusB
749 Views, 2 Replies
After having copied objects (3d faces) from working database to a side database, I open the dwg through the above mentioned method. However, then when I right-click in the drawing (and all other drawings that are open) the last command is repeated although according to the right-click customization settings in OPTIONS, ACAD is supposed to show the short cut menu in all "modes" (Edit, Command etc).
If I don't open the drawing programmatically, but use the GUI instead, then the right-click menu appears on right click (as expected).
2B or not 2B? That is the question! The answer is FF.
2 REPLIES 2
RasmusB
in reply to: RasmusB
If I go into Right-click customization and choose to always enable Shortcut Menu in Command Mode (instead of only when command options are present), then the right-click menu appears each time I right click...If I check the CMDACTIVE variable, it tells me that an ordinary command is active (1), and according to CMDNAMES this is the SETVAR (but this is always the case?).
ow
Try switching NEXTFIBERWORLD.
”Boost
