.NET
.NET
luisibad
Message 1 of 4 (650 Views)
Problem when debugging AutoCAD 2014 with Visual Studio 2013
650 Views, 3 Replies
11-17-2013 03:31 AM
Hi! I had this problem before when I launched AutoCAD in this error appeared:
AutoCAD - Missing or corrupt display driver
A display driver file (.hdi) is missing or has been corrupted.
the Program will be closed
This problem may be caused by missing .hdi files in the following location:
C:\Program Files\Autodesk\AutoCAD 2014\Drv\
I sorted it out changed the target:
"C:\Program Files\Autodesk\AutoCAD 2014\acad.exe" /ld "C:\Program Files\Autodesk\AutoCAD 2014\AecBase.dbx" /p "AutoCAD Architecture (US Metric)" /NOHARDWARE /product "ACA" /language "en-US"
I meant, I added "/NOHARDWARE " because I found the solution in Autodesk Community and it helps because I can launch without problem.
But when I started to use visual studio 2013 with AutoCAD 2014 the problem appears again and I can't start to develop my programs because of them
Some idea for it?
Thanks.
Alfred.NESWADBA
Message 2 of 4 (643 Views)
Re: Problem when debugging AutoCAD 2014 with Visual Studio 2013
11-17-2013 03:53 AM in reply to: luisibad
You mentioned that you had set start-parameters like /NOHARDWARE to go around the problem, have you set this parameter also in debug-page if the vs-environment?
(sorry for the German screenshot, I have no English VS)
- alfred -
Alfred NESWADBA
luisibad
Message 3 of 4 (617 Views)
11-17-2013 05:49 AM in reply to: Alfred.NESWADBA
I didn't set that parameter, I did it and it works
Thanks you!
Jeff_M
Message 4 of 4 (603 Views)
11-17-2013 08:24 AM in reply to: luisibad
If you find a response which answers your question, please be sure to accept the actual post which helped you as the solution. This will help future searchers quickly find answers to their own questions. Thanks!
