Hi! I had this problem before when I launched AutoCAD in this error appeared:
AutoCAD - Missing or corrupt display driver
A display driver file (.hdi) is missing or has been corrupted.
the Program will be closed
This problem may be caused by missing .hdi files in the following location:
C:\Program Files\Autodesk\AutoCAD 2014\Drv\
I sorted it out changed the target:
"C:\Program Files\Autodesk\AutoCAD 2014\acad.exe" /ld "C:\Program Files\Autodesk\AutoCAD 2014\AecBase.dbx" /p "AutoCAD Architecture (US Metric)" /NOHARDWARE /product "ACA" /language "en-US"
I meant, I added "/NOHARDWARE " because I found the solution in Autodesk Community and it helps because I can launch without problem.
But when I started to use visual studio 2013 with AutoCAD 2014 the problem appears again and I can't start to develop my programs because of them
Some idea for it?
Thanks.
Solved by Alfred.NESWADBA. Go to Solution.
You mentioned that you had set start-parameters like /NOHARDWARE to go around the problem, have you set this parameter also in debug-page if the vs-environment?
(sorry for the German screenshot, I have no English VS)
- alfred -
