.NET
Problem in Initialize() method
3 REPLIES 3
345 Views, 3 Replies
Hi ,
I am facing a problem during initialize method of a DLL. During initialiazation it throw following error message.
 It happens only when I am using ACAD 2010 and try to load DLL from network. When I try to load the DLL form local disc then it works fine. I try in ACAD 2011 where it also works fine from network. Can anybody give me any clue how to resolve this problem. I am attaching the project so that anybody reproduce this problem.
Regards
Zakir
3 REPLIES 3
hgasty1001
Not sure, but you can try adding this line to the acad.exe.config (in the AutoCAD folder) in the runtime section:
<runtime>
<loadFromRemoteSources enabled="true" />
</runtime>
Gaston Nunez
in reply to: hgasty1001
I have tried that before posting this message but no luck. What I have found that if I remove the reference of PresentationCore.DLL then there is not problem of initialization. But I need that reference. Everything is working fine if I load the dll from local disc.
fieldguy
Do a search for CASPOL - this forum or google.
”Boost
