.NET
Problem creating rotated Viewport
3 REPLIES 3
stephanhollaus
458 Views, 3 Replies
Hi
I'm trying to create a rotated vie but have a big problem. When I create the View "non rotated" everythig is fine. But when I try to rotate the View via twistangle the Viewcenter is wrong.
Here is my Code
Dim tAF As New DatabaseServices.Viewport
tAF.ViewCenter = midpnt
tAF.CenterPoint = AfCenterPoint
tAF.Width = AFWitdth
tAF.Height = AFHeigth
tAF.ViewHeight = imgHeigt
Dim LayIDAF As DatabaseServices.ObjectId = ISHAcTools.createLayer(ta, doc.Database, "MANSFEN")
tAF.LayerId = LayIDAF
tAF.TwistAngle = ImgCom.Rotation
tLayoutBlDef.AppendEntity(tAF)
ta.AddNewlyCreatedDBObject(tAF, True)
Can anybody tell me where the problem is?
thx
sincerly
3 REPLIES 3
dmcknight
in reply to: stephanhollaus
Since you typically have to choose something within the viewport to use "twist", I would guess that you have to choose items within that viewport.
boughannam
I have the same problem. Did you find a solution.
Balaji_Ram
in reply to: boughannam
Here is a blog post that explains the ViewTwist calculation :
http://adndevblog.typepad.com/autocad/2012/06/calculating-viewtwist-variable.html
Can you please verify if the view twist that you are providing is correct ?
Balaji
Developer Technical Services
Autodesk Developer Network
”Boost
