.NET
Contributor bej
bej
Message 1 of 5 (307 Views)
Problem creating multiple (100+) drawings using .NET
307 Views, 4 Replies
08-14-2013 02:47 AM
I have an application that creates multiple new DWG files, fill them with some geometry, and closes the files again, before repeating.
The problem I've encountered is that AutoCAD will crash somewhat randomly with a Fatal Error if I repeat the NEW FILE/CLOSE FILE process several hundred times. The application works fine as long as not too many files are created.
Below is the source code of a test example I've created that will produce this problem. In this test example I simply create and close DWG files without adding any data to them:
dwgHandler.h
ref class dwgHandler
private:
  DocumentCollection ^ docMgr;
  Document ^ doc;
  Database ^ db;
  Editor ^ ed;
  Transaction ^tr;
  BlockTable ^bt;
  BlockTableRecord ^ms;
  RegAppTable ^rat;
  LayerTable ^lt;
public:
  dwgHandler(void);
  ~dwgHandler(void);
  void newDrawing(String ^templateFile);
  void closeAndSaveDrawing(String ^dwgfile);
  void beginTransaction();
  void endTransaction();
dwgHandler.cpp
dwgHandler::dwgHandler(void)
dwgHandler::~dwgHandler(void)
void dwgHandler::newDrawing(String ^templateFile)
  try
    // new file
    docMgr = Autodesk::AutoCAD::ApplicationServices::Core::Application::smileyvery-happy:ocumentManager;
    doc = DocumentCollectionExtension::Add(docMgr, templateFile);
    docMgr->MdiActiveDocument = doc;
    doc->LockDocument();
    // begin transaction
    beginTransaction();
  catch (System::Exception ^ ex)
    MessageBox::smileyfrustrated:how("Unable to open new drawing: " + ex);
    return;
void dwgHandler::beginTransaction()
try
  db = doc->Database;
  ed = doc->Editor;
  tr = db->TransactionManager->StartTransaction();
  bt =(BlockTable^)tr->GetObject(db->BlockTableId, OpenMode::ForRead);
  ms =(BlockTableRecord^)tr->GetObject(bt[BlockTableRecord::ModelSpace], OpenMode::ForWrite);
  rat = (RegAppTable^)tr->GetObject(db->RegAppTableId, OpenMode::ForWrite, false);
  lt = (LayerTable^)tr->GetObject(db->LayerTableId,OpenMode::ForWrite);
  MessageBox::smileyfrustrated:how("Unable to begin transaction: " + ex);
  return;
void dwgHandler::closeAndSaveDrawing(String ^dwgfile)
try
  // endTransaction
  endTransaction();
  // Save and close the active drawing
  doc->Database->SaveAs(dwgfile, true, DwgVersion::Current,doc->Database->SecurityParameters);
  DocumentExtension::CloseAndDiscard(doc);
  MessageBox::smileyfrustrated:how("Unable to save drawing. Please save manually.", "ImportPDMS", MessageBoxButtons::smileysurprised:K,
void dwgHandler::endTransaction()
try
  tr->Commit();
  MessageBox::smileyfrustrated:how("failed to end transaction: " + ex);
testHandler.cpp
void testHandler()
String ^outputFile;
for(int i=1; i<500; i++)
  // new dwghandler
  dwgHandler ^dwgh=gcnew dwgHandler();
  // new drawing
  dwgh->newDrawing("acadiso.dwt");
  // save drawing
  outputFile="c:\\test\\testfile" + i.ToString() + ".dwg";
  dwgh->closeAndSaveDrawing(outputFile);
  // delete dwghandler
  delete dwgh;
When running testHandler() AutoCAD will crash with a Fatal Error randomly, but usually not before 300+ files have been created.
Is there anything I'm doing wrong in this example?
Bjørn Egil Jenssen
*Expert Elite*
Hallex
Message 2 of 5 (296 Views)
Re: Problem creating multiple (100+) drawings using .NET
08-14-2013 03:52 AM in reply to: bej
Please repost your question on C++ branch:
http://forums.autodesk.com/t5/Autodesk-ObjectARX/bd-p/34
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Contributor bej
bej
Message 3 of 5 (292 Views)
08-14-2013 03:55 AM in reply to: Hallex
This is not ObjectARX code, but CLI. I'm only using the .NET API's.
Contributor bej
bej
Message 4 of 5 (289 Views)
08-14-2013 03:57 AM in reply to: bej
Just to clarify. I'm coding in C++/CLI, but I'm using only the AutoCAD .NET API's.
ADN Support Specialist
philippe.leefsma
Message 5 of 5 (205 Views)
08-21-2013 08:37 AM in reply to: bej
One suggestion would be to create an exe application that will act as a loader, restarting AutoCAD after a series of drawings to prevent it from crashing.
I hope it helps.
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
Post to the Community
New Post
Need installation help?
