.NET
.NET
Valued Contributor
ognyandim
Message 1 of 3 (358 Views)
Problem calling WCF Service from within AutoCAD 2012
358 Views, 2 Replies
01-01-2012 02:52 PM
Hello everybody!
I am experiencing a strange problem and I suppose it is because of some technical detail that I dont currently know.
I have done the first chapter from Windows Communication Foundation 4 Step by Step.
I have built myself a simple service and separete console client that talks with the service and it goes pretty well.
I have made absolutley the same client inside AutoCAD 2012 x64 and tried to call the service and I receive the following error provided on screenshot.
I have provided both codes for you to see. Can you explain the problem? If you provide me a link to something I will be greatful.
I am going to answer it here myself.
We need the app.config loaded. When we have Conosle Client App the config is loaded, but when we make a library client ( .dll that we have to NETLOAD ) it is not loaded anywhere and therefore the config is unavailible.
I have solved my problem by pasting the configuration in acad.exe.config. That way my WCF client config is availible the to .dll which is hosted inside AutoCAD.
Here I have found a pretty good intro video for WCF hosted inside AutoCAD. ( Mine was outside of AutoCAD ) :
http://au.autodesk.com/?nd=event_class&jid=610987&session_id=7182
Valued Contributor
ognyandim
Message 2 of 3 (353 Views)
Re: Problem calling WCF Service from within AutoCAD 2012
01-01-2012 03:39 PM in reply to: ognyandim
http://through-the-interface.typepad.com/through_the_interface/2008/01/turning-autocad.html - Kean implemented a thing that calls outside in another way, but that is not exactly what I am looking for.
Valued Contributor
ognyandim
Message 3 of 3 (350 Views)
01-01-2012 04:16 PM in reply to: ognyandim
