.NET
Problem:ACFocusCtrl16.dll failed. To register HRESULT-2147024770 contact to
4 REPLIES 4
naresh
384 Views, 4 Replies
"ACFocusCtrl16.dll failed. To register HRESULT-2147024770 contact your support personnel" This error is occouring while i am trying to create setup of C# application which uses AutoCAD drawings for operations.Please anybody have solution for this then please write here
Thanks in advance
4 REPLIES 4
NathTay
in reply to: naresh
Is it necessary for .NET forms?
Regards - Nathan
naresh
in reply to: naresh
No I think it is necessary for VBA only but still I am facing this problem what shall I do to overcome this problem
NathTay
in reply to: naresh
If it is not necessary then why are you trying to use it?
Regards - Nathan
naresh
in reply to: naresh
Yaa!!! you were right
Actually at the time of development I had added that dll to my project for some reason later i forgot to remove it from project thank you for reminding me now its working perfectly
”Boost
