Hi..
The following code was copied from ‘autocad 2013 help’.
When I debug the code of help file, the autocad is open and there is ERROR named strDWGName=”C:MyDrawing.dwg”..
but, I revised the name to strDWGName=”MyDrawing.dwg” and then, the file is saved in the DEBUG folder WITHOUT ANY ERROR.
Could you please explain this matter in details?
Save the active drawing
This example saves the active drawing to "c:\MyDrawing.dwg" if it is currently not saved or under its current name.
VB.NET
Imports Autodesk.AutoCAD.ApplicationServices Imports Autodesk.AutoCAD.Runtime <CommandMethod("SaveActiveDrawing")> _ Public Sub SaveActiveDrawing() Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument Dim strDWGName As String = acDoc.Name Dim obj As Object = Application.GetSystemVariable("DWGTITLED") '' Check to see if the drawing has been named If System.Convert.ToInt16(obj) = 0 Then '' If the drawing is using a default name (Drawing1, Drawing2, etc) '' then provide a new name strDWGName = "c:\MyDrawing.dwg" End If '' Save the active drawing acDoc.Database.SaveAs(strDWGName, True, DwgVersion.Current, _ acDoc.Database.SecurityParameters) End Sub
Solved by norman.yuan. Go to Solution.
What do you want to be explanined? Why you expect error when there should not be an error? If you supply a file name without path, where you expect the file is samed to? Hint: AutoCAD takes the application's current folder, which is where the application is loaded from.
Norman Yuan
