.NET
matus.brlit
Message 1 of 12 (899 Views)
PrinterConfigPath with two paths
899 Views, 11 Replies
05-10-2012 08:18 AM
I'm trying to set two locations in PrinterConfigPath, but it crashes with fatal error
Dim pref As AcadPreferences = Autodesk.AutoCAD.ApplicationServices.Application.Preferences
pref.Files.PrinterConfigPath = "T:\wPlotters;T:\Plotters"
note 1: one location works fine, but i can't figure out, how to put 2 locations there
note 2: when i set those paths manually, the property contains exactly that string
I did not try your's code but the same can be done with help of setting environment "PrinterConfigDir" (ObjectARX functions acedGetEnv/acedSetEnv and lisp functions (getenv) and (setenv).
How to call acedGetEnv/acedSetEnv from .NET:
http://www.theswamp.org/index.php?topic=33594.0
http://www.theswamp.org/index.php?topic=20237.msg362493#msg362493
http://www.caduser.ru/forum/index.php?PAGE_NAME=message&FID=49&TID=36668&MID=208004#message208004
Minimum testing with AutoCAD 2013.
C#:
using System;
using System.Runtime.InteropServices;
using System.Text;
using System.Windows.Forms;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.EditorInput;
using AcRx = Autodesk.AutoCAD.Runtime;
using AcEd = Autodesk.AutoCAD.EditorInput;
using AcDb = Autodesk.AutoCAD.DatabaseServices;
using AcAp = Autodesk.AutoCAD.ApplicationServices;
using AcWin = Autodesk.AutoCAD.Windows;
[assembly: CommandClass(typeof(SetEnvInNet.MyCommands))]
namespace SetEnvInNet
public static class Env
static int Ver = AcAp.Application.Version.Major;
// AutoCAD 2007...2012
[DllImport("acad.exe", CallingConvention = CallingConvention.Cdecl, CharSet = CharSet.Unicode, EntryPoint = "acedGetEnv")]
extern static private Int32 acedGetEnv12(string var, StringBuilder val);
// AutoCAD 2013...
[DllImport("accore.dll", CallingConvention = CallingConvention.Cdecl, CharSet = CharSet.Unicode, EntryPoint = "acedGetEnv")]
extern static private Int32 acedGetEnv13(string var, StringBuilder val);
static public string GetEnv(string var)
StringBuilder val = new StringBuilder(16536);
if (Ver <= 12) acedGetEnv12(var, val); else acedGetEnv13(var, val);
return val.ToString();
[DllImport("acad.exe", CallingConvention = CallingConvention.Cdecl, CharSet = CharSet.Unicode, EntryPoint = "acedSetEnv")]
extern static private Int32 acedSetEnv12(string var, string val);
// AutoCAD 2013...
[DllImport("accore.dll", CallingConvention = CallingConvention.Cdecl, CharSet = CharSet.Unicode, EntryPoint = "acedSetEnv")]
extern static private Int32 acedSetEnv13(string var, string val);
static public void SetEnv(string var, string val)
if (Ver <= 12) acedSetEnv12(var, val); else acedSetEnv13(var, val);
public class MyCommands
static public void AddPath(string var, string path)
StringBuilder oldpath = new StringBuilder(Env.GetEnv(var));
oldpath.Append(";"); oldpath.Append(path);
Env.SetEnv(var, oldpath.ToString());
[CommandMethod("SetPath", CommandFlags.Modal)]
public void TestAddPath()
AcWin.OpenFileDialog dlg = new AcWin.OpenFileDialog("Select Directory:", "", "", "",
AcWin.OpenFileDialog.OpenFileDialogFlags.AllowFoldersOnly);
DialogResult ds = dlg.ShowDialog();
if (ds == DialogResult.OK)
AddPath("PrinterConfigDir",dlg.Filename);
 VB.NET (converted from C# with http://www.developerfusion.com/tools/convert/csharp-to-vb/)
Imports System.Runtime.InteropServices
Imports System.Text
Imports System.Windows.Forms
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.EditorInput
Imports AcRx = Autodesk.AutoCAD.Runtime
Imports AcEd = Autodesk.AutoCAD.EditorInput
Imports AcDb = Autodesk.AutoCAD.DatabaseServices
Imports AcAp = Autodesk.AutoCAD.ApplicationServices
Imports AcWin = Autodesk.AutoCAD.Windows
<Assembly: CommandClass(GetType(SetEnvInNet.MyCommands))>
Namespace SetEnvInNet
Public NotInheritable Class Env
Private Sub New()
End Sub
Shared Ver As Integer = AcAp.Application.Version.Major
' AutoCAD 2007...2012
<DllImport("acad.exe", CallingConvention := CallingConvention.Cdecl, CharSet := CharSet.Unicode, EntryPoint := "acedGetEnv")> _
Private Shared Function acedGetEnv12(var As String, val As StringBuilder) As Int32
End Function
' AutoCAD 2013...
<DllImport("accore.dll", CallingConvention := CallingConvention.Cdecl, CharSet := CharSet.Unicode, EntryPoint := "acedGetEnv")> _
Private Shared Function acedGetEnv13(var As String, val As StringBuilder) As Int32
End Function
Public Shared Function GetEnv(var As String) As String
Dim val As New StringBuilder(16536)
If Ver <= 12 Then
Else
End If
Return val.ToString()
End Function
<DllImport("acad.exe", CallingConvention := CallingConvention.Cdecl, CharSet := CharSet.Unicode, EntryPoint := "acedSetEnv")> _
Private Shared Function acedSetEnv12(var As String, val As String) As Int32
End Function
' AutoCAD 2013...
<DllImport("accore.dll", CallingConvention := CallingConvention.Cdecl, CharSet := CharSet.Unicode, EntryPoint := "acedSetEnv")> _
Private Shared Function acedSetEnv13(var As String, val As String) As Int32
End Function
Public Shared Sub SetEnv(var As String, val As String)
If Ver <= 12 Then
Else
End If
End Sub
End Class
Public Class MyCommands
Public Shared Sub AddPath(var As String, path As String)
Dim oldpath As New StringBuilder(Env.GetEnv(var))
oldpath.Append(";")
End Sub
<CommandMethod("SetPath", CommandFlags.Modal)> _
Public Sub TestAddPath()
Dim dlg As New AcWin.OpenFileDialog("Select Directory:", "", "", "", AcWin.OpenFileDialog.OpenFileDialogFlags.AllowFoldersOnly)
Dim ds As DialogResult = dlg.ShowDialog()
If ds = DialogResult.OK Then
AddPath("PrinterConfigDir", dlg.Filename)
End If
End Sub
End Class
End Namespace
Distinguished Contributor
VB_Autocad_guy
Message 2 of 12 (875 Views)
Re: PrinterConfigPath with two paths
05-15-2012 12:00 PM in reply to: matus.brlit
Hmmm..
What version of Autocad and what version of Visual Studio?
matus.brlit
Message 3 of 12 (863 Views)
05-15-2012 10:20 PM in reply to: VB_Autocad_guy
AutoCAD 2012, VS Express 2008
Moderator
Alexander.Rivilis
Message 4 of 12 (851 Views)
05-16-2012 12:31 AM in reply to: matus.brlit
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
VB_Autocad_guy
Message 5 of 12 (835 Views)
05-16-2012 03:39 PM in reply to: matus.brlit
Okay so Here's some sample code I don't have any problem using the Autocad Preferences Object
    Public Application As Autodesk.AutoCAD.ApplicationServices.Application 'VB.NET Application Object
 Try
            'Acad Preferences Objects
            Dim acPrefComObj As AcadPreferences = Application.Preferences
            'Set Support Paths & Preferences
            With acPrefComObj.Files
                'Editor.WriteMessage("Entered Loop")
                'Change Value in Autocad Preferences if Variable is NOT empty---------------
                .CustomIconPath = sCustomIconPath
                .DriversPath = sDriversPath
               .PrinterDescPath = sPrinterConfigPath
               .PrinterConfigPath = sPrinterConfigPath
               .PrinterStyleSheetPath = sPrinterStyleSheetPath
                .SupportPath = sSupportPath
                .TempFilePath = sTempFilePath
                .TemplateDwgPath = sTemplateDwgPath
                 .ToolPalettePath = sToolPalettePath
                .AutoSavePath = sAutoSavePath
            End With
            Editor.WriteMessage(vbTab & "<<[Support Paths Set>>" & Environment.NewLine)
            'AUTOSAVE SET
            With acPrefComObj.OpenSave
                .AutoSaveInterval = 11
            End With
            Editor.WriteMessage(vbTab & "<<AutoSave Interval Set>>" & Environment.NewLine)
            'DefaultPlot File Path & Printer
            With acPrefComObj.Output
                .DefaultPlotToFilePath = _
                Environment.GetFolderPath(Environment.SpecialFolder.MyDocuments)
                .DefaultOutputDevice = DefaultPrinterName()
            End With
            Editor.WriteMessage(vbTab & "<<Default Printer Set>>" & Environment.NewLine)
            Editor.WriteMessage(vbTab & "<<Support Settings Done>>" & Environment.NewLine)
            Editor.WriteMessage(vbTab & "<<----------------------------------------------->>" & Environment.NewLine)
        Catch ex As Exception
            Editor.WriteMessage("[ERROR:" & ex.Message & vbTab & ex.ErrorStatus.ToString)
        End Try
VB_Autocad_guy
Message 6 of 12 (828 Views)
05-16-2012 03:49 PM in reply to: VB_Autocad_guy
I tested your code on my machine. Invalid Argurment error.
Doesn't like two different paths. Huh?
Who would have thought.
Moderator
Alexander.Rivilis
Message 7 of 12 (820 Views)
05-16-2012 09:22 PM in reply to: VB_Autocad_guy
The previous version of AutoCAD was not allowed to have more than one path in PrinterConfigPath. That is why there is a problem with Autocad Preferences Object (IMHO). If so, then the only solution - to use acedSetEnv as I wrote above.
matus.brlit
Message 8 of 12 (815 Views)
05-16-2012 10:28 PM in reply to: Alexander.Rivilis
OK, I will give it a try. I was waiting for another possible solution, because I don't fully understand that invoke voodoo, so I try to avoid it, if I can.
Moderator
Alexander.Rivilis
Message 9 of 12 (807 Views)
05-17-2012 02:46 AM in reply to: matus.brlit
C#:
using System;
using System.Text;
        // AutoCAD 2013...
        // AutoCAD 2013...
Imports System.Text
		Private Sub New()
		End Sub
		End Function
		' AutoCAD 2013...
		End Function
			If Ver <= 12 Then
			Else
			End If
		End Function
		End Function
		' AutoCAD 2013...
		End Function
			If Ver <= 12 Then
			Else
			End If
		End Sub
	End Class
			oldpath.Append(";")
		End Sub
			End If
		End Sub
	End Class
End Namespace
Rob.O
Message 10 of 12 (248 Views)
04-02-2014 04:13 PM in reply to: Alexander.Rivilis
I know this topic is a couple of years old, but I am trying to replicate this in 2015 with no sucess.
Has anyone written an update that works in 2015?
Strange thing... if I strip out all of the Initialization functionality, and turn it into a class library, I can get it to work through an Visual Studio debug session.  But if I build the solution and startup AutoCAD detached from Visual Studio, it will not run properly after NETLOADing the function.  It runs, but after I open the Options dialog, it hangs for about 2 minutes before it finally opens.  Then, the paths are only displying the latest value entered instead of both values I have added.
Anyone know of a reason why it would work through a debug session, but not through a detached session of AutoCAD?
TIA!
Rob
