.NET
printer stored in dwg file
4 REPLIES 4
496 Views, 4 Replies
I have a problem with plotting dwg files using vb net.
When in this files is stored a printer no more existing in my network I've an exception in my vb net program.
How can I clean any information about printers stored in files?
To plot these files I use "acadDoc.SendCommand("-stampa" + vbCr + "S" + vbCr + "model" _ ....."
4 REPLIES 4
fenton.webb
Please post more information and the code that goes wrong
Fenton Webb
AutoCAD Engineering
in reply to: fenton.webb
through a vb net dll I print dwg files using
        acadDoc = AcadApp.ActiveDocument
        + vbCr + nDevice + vbCr + fmtPrint + vbCr + "M" + vbCr + orientPAGE _
        + vbCr + "n" + Chr(13) + "E" + vbCr + "Adatta" + vbCr + "Center" + vbCr _
        + "S" + vbCr + "Giben.ctb" + vbCr + "S" + vbCr + "n" + vbCr + "N" _
        + vbCr + "N" + vbCr + "S" + vbCr)
my problem is when in dwg layout is strored a printer no more existing (as you can see in the layout.jpg image). In this case I obtain the error in error.jpg image. Unfortunatly this warning are in Italian 🙂 I hope it's not a big problem for you
Balaji_Ram
If you think the printer name associated with the PlotSettings is not valid, you can reset it to default before going ahead with the plot. Here is a sample code to reset it :
[CommandMethod("ResetPS")]
public void ResetPSMethod()
    Document doc = Application.DocumentManager.MdiActiveDocument;
    Editor ed = doc.Editor;
    Database db = doc.Database;
    Transaction tr = db.TransactionManager.StartTransaction();
    using (tr)
        BlockTableRecord btr = tr.GetObject(db.CurrentSpaceId, OpenMode.ForRead) as BlockTableRecord;
        Layout lo = tr.GetObject(btr.LayoutId, OpenMode.ForRead) as Layout;
        PlotInfo pi = new PlotInfo();
        pi.Layout = btr.LayoutId;
        PlotSettings ps = new PlotSettings(lo.ModelType);
        PlotSettingsValidator psv = PlotSettingsValidator.Current;
        pi.OverrideSettings = ps;
        PlotInfoValidator piv = new PlotInfoValidator();
        piv.MediaMatchingPolicy = MatchingPolicy.MatchEnabled;
        piv.Validate(pi);
        lo.UpgradeOpen();
        lo.CopyFrom(ps);
        tr.Commit();
    ed.Regen();
Balaji
Developer Technical Services
Autodesk Developer Network
in reply to: Balaji_Ram
Thank's it's perfect J
Cordiali saluti
Gianni Albori - CED
Giben International Spa
Questo messaggio di posta elettronica contiene informazioni di carattere confidenziale rivolte esclusivamente al destinatario sopra indicato.
E' vietato l'uso, la diffusione, distribuzione o riproduzione del messaggio intero o di parte di esso a chiunque non ne sia il diretto destinatario. Nel caso aveste ricevuto questo messaggio di posta elettronica per errore, siete pregati di segnalarlo immediatamente al mittente e distruggere quanto ricevuto (compresi i file allegati) senza farne copia.
Qualsiasi utilizzo non autorizzato del contenuto di questo messaggio costituisce violazione dell'obbligo di non prendere cognizione della corrispondenza tra altri soggetti, salvo piu grave illecito, ed espone il responsabile alle relative conseguenze.
Confidentially notice. This e-mail transmission may contain legally privileged and/or confidential information. Please do not read it if you are not the intended recipient(S).
Any use, distribution, reproduction or disclosure by any other person is strictly prohibited.
If you have received this e-mail in error, please notify the sender and destroy the original transmission and its attachments without reading or saving it in any manner.
”Boost
