.NET
Valued Contributor
stuartnathan
Message 1 of 14 (887 Views)
Printer Paper Sizes
887 Views, 13 Replies
12-27-2011 02:33 AM
I am trying to get the various sizes of paper for each printer. I can do this for Windows Printers.
But I also want to get the sizes of the .pc3 files.
So far I have this.
   Friend Function GetPaperSizes(ByVal Plotter As String) As StringCollection
      For i = 0 To PrinterSettings.InstalledPrinters.Count - 1
         ps.PrinterName = PrinterSettings.InstalledPrinters.Item(i)
         For j = 0 To ps.PaperSizes.Count - 1
            pz = ps.PaperSizes.Item(j)
            AcadEdt.WriteMessage(vbLf & pz.PaperName & " w=" & pz.Width * 0.254 & " h=" & pz.Height * 0.254)
         Next
      Next
      Dim p As PlotConfig = PlotConfigManager.SetCurrentConfig(Plotter)
      Dim t As String = p.Comment
      AcadEdt.WriteMessage(vbLf & t)
      Using tr As Transaction = CurDb.TransactionManager.StartTransaction()
         Dim lyMgr As LayoutManager = LayoutManager.Current                               '  Get the current layout
         Dim cLayout As Layout = tr.GetObject(lyMgr.GetLayoutId(lyMgr.CurrentLayout), OpenMode.ForRead)
         Dim cpInfo As PlotInfo = New PlotInfo()                                          '  Get the PlotInfo from the layout
         cpInfo.Layout = cLayout.ObjectId                                                 '  Get a copy of the PlotSettings from the layout
         Dim cpSet As PlotSettings = New PlotSettings(cLayout.ModelType)
         cpSet.CopyFrom(cLayout)                                                          '  Update the PlotConfigurationName property of the PlotSettings object
         Dim s As String = pl.Comment
         '  Returns a list of media sizes that are supported for the current device or the PC3 files. (Acad Help)
         '  except that it always returns ""
         Dim cpVdr As PlotSettingsValidator = PlotSettingsValidator.Current
         Try
            Return cpVdr.GetCanonicalMediaNameList(cpSet)
         Catch ex As Exception
            Return Nothing
         End Try
      End Using
   End Function
 So,
I am looking for the various sheet descriptions + width and height.
All help gratefully received.
These (C#) samples may help you to find the answers.
1: QueryPlotters()
2: QueryMediaNames()
3: QueryPlotStyles()
4: QueryPaperSize()
5: QueryNamedPlotStyles()
6: QueryDetailedNamedPlotStyles()
SENL1362
Message 2 of 14 (868 Views)
Re: Printer Paper Sizes
12-28-2011 02:41 AM in reply to: stuartnathan
1: QueryPlotters()
4: QueryPaperSize()
Valued Contributor
stuartnathan
Message 3 of 14 (861 Views)
12-28-2011 03:01 AM in reply to: SENL1362
Thanks for your help.
I've got a bit of this already, but you may well have found the missing bits for me.
Let me have a look and I'll get back to you.
SENL1362
Message 4 of 14 (857 Views)
12-28-2011 03:10 AM in reply to: stuartnathan
Watchout for the custom papersizes when creating NamedPlotStyles.
These custom papersizes are referenced by their internal id and those  may alter when newley defined in a PC3 file or in the Printer.
Valued Contributor
stuartnathan
Message 5 of 14 (853 Views)
12-28-2011 03:23 AM in reply to: SENL1362
OK. Converted to VB and tried the code
   Public Sub QueryDetailedNamedPlotStyles()
       Dim plSetVdr As PlotSettingsValidator = PlotSettingsValidator.Current
      CurDb.TileMode = False
      AcadEdt.SwitchToPaperSpace()
         Dim plotDict As DBDictionary = DirectCast(CurDb.PlotSettingsDictionaryId.GetObject(OpenMode.ForRead), DBDictionary)
         AcadEdt.WriteMessage(vbLf & "{0} NamedPlotStyles", plotDict.Count)
 etc.
plotDict.Count alwats returns 0, so I don't get the sizes etc.
I went to Page Setup, ensured I had a plotter set etc.
However, in reality the idea is to plot automatically so people don't have to setup Page.
SENL1362
Message 6 of 14 (847 Views)
12-28-2011 03:43 AM in reply to: stuartnathan
Propably an empty drawing -- no Named Plot Styles.
Try to add some from within paperspace: File/Page Setup Manager/New...
Enter Printer/Pc3, Papersize, PlotArea, PlotScale, Orientation  and Pen Table
Valued Contributor
stuartnathan
Message 7 of 14 (842 Views)
12-28-2011 04:09 AM in reply to: SENL1362
Sorry. Didn't look closely enough.
I think QueryMediaNames may do the trick.
Incidently, I didn't know you could do what you do with the WriteMessage function. Neat.
I'll get back
SENL1362
Message 8 of 14 (840 Views)
12-28-2011 04:30 AM in reply to: stuartnathan
Do you referring to the Formatting of strings such as in:
  ed.WriteMessage("\n\tPaper: {0:0.00} X {1:0.00} ({2})",  ps.PlotPaperSize.X, ps.PlotPaperSize.Y, ps.CanonicalMediaName);
You  can use that  in any  String  operation, like
   String myFormattedString =String.Format("{0:0.0}", TheValue);            // "0.0"
    String.Format("{0:0.0}", 0.0);            // "0.0"
    String.Format("{0:0.#}", 0.0);            // "0"
Valued Contributor
stuartnathan
Message 9 of 14 (830 Views)
12-28-2011 08:07 AM in reply to: SENL1362
I've got it working and it is just what I want.
PSizes is used elsewhere and is a global variable. It contains the Width and Height and I use the CanonicalMediaName as a key.
a_Paper.Suffix is read from an INI file and contains MM, or CM or INCHES etc.
So my code is this:
   Public Sub QueryMediaNames()
      PSizes = New Collection
      Dim layMgr As LayoutManager = LayoutManager.Current
         Dim ly As Layout = DirectCast(tr.GetObject(layMgr.GetLayoutId(layMgr.CurrentLayout), OpenMode.ForRead), Layout)
         Dim np As New PlotSettings(ly.ModelType)
         np.CopyFrom(ly)
         Dim canMedNames As StringCollection = plSetVdr.GetCanonicalMediaNameList(np)
         Dim i As Integer, s As String
         For Each c As String In canMedNames
            If c.ToUpper.Contains(a_Paper.Suffix.ToUpper) Then
               i = InStr(c, "(")
               If i > 0 Then
                  Dim p As gs_Size
                  s = c.Substring(i)
                  s = s.Substring(0, s.Length - 4)
                  i = InStr(s, "_x_")
                  p.Width = CSng(s.Substring(0, i - 1))
                  p.Height = CSng(s.Substring(i + 2))
                  PSizes.Add(p, c)
               End If
            End If
         Next
      End Using
   End Sub
I now need to use the paper sizes.
Valued Mentor
jeff
Message 10 of 14 (826 Views)
12-28-2011 09:39 AM in reply to: stuartnathan
You can create a global variable using CIL but I do not think you can in VB.NET
You can also find your answers @ TheSwamp
