I need to set the Printer Configuration Search Path and the Plot Style Table Search Path. Currently I am using COM but the issue I have is that I need to run the same application on 2 different machines, one has only Autocad 2010 (xp-32bit), the other has both Autocad 2010 and Autocad 2012(win7-64bit) and I've got some difficulty to have it running.
Can I set those paths without using COM?
Thanks for your help.
e.g.
you may read the values from the registry (within the active profile).
The other option would be to use COM-access with the reflection-methods as Hallex showed it >>>here<<<, that makes it possible to use COM without need to reference the ActiveX components/interfaces (activation of late-binding is then necessary I think)
HTH, - alfred -
