Hi all,
is it possible to set 'Previous_paper_size_(4140.00_x_2660.00_MM)' in paper size tab and plotter as 'DWF6 ePlot.pc3' for active layout using dotnet.
i have tried for other paper size present in the drop down list it comes fine. but it says exception for previous paper size. is there posisbility that i can set this through program. and also i dont want to use any template dwg to import pagesetup.
thanks
sonu
