.NET
Active Contributor
murali.pandey
Message 1 of 4 (144 Views)
preview AutoCad Map query
144 Views, 3 Replies
04-25-2012 11:50 PM
how can I  query autocad map data in preview mode,and store these objects in a collection by using C#.
(I want to use simple query like all lwpolyline having layer = "test" and color = 3). If I run this query in draw mode multiple times what will happen? (means possibilty of duplicate objects??)
Murali
Alfred.NESWADBA
Message 2 of 4 (143 Views)
Re: preview AutoCad Map query
04-25-2012 11:57 PM in reply to: murali.pandey
do you need any Map3D functionality like re-projection depending on different geo-coord-systems or something like saveback?
If not I had much more luck replace the Map-query-functionality by my own routine, just
  • open the external database(s)
  • get the modelspace-blocktablerecord
  • scan it to get the objectid's matching the ObjectClass (DxfName of the Objecttype), if the objecttype is correct you can then check the other properties you want to compare
  • does the object match, collect it by saving handle and drawing-filename into an own list.
- alfred -
Alfred NESWADBA
Active Contributor
murali.pandey
Message 3 of 4 (140 Views)
04-26-2012 12:07 AM in reply to: Alfred.NESWADBA
I have to use map query only to show(preview) the quried data into the current drawing and do not want to do any type of editing in quried dwg. Before it I have to set the coordinate system say XYZ of the curent dwg.
Murali
Alfred.NESWADBA
Message 4 of 4 (137 Views)
04-26-2012 12:13 AM in reply to: murali.pandey
E.g. use WorlDraw (or at least JIG without mouse-move-following) then, it's just a preview and not the adding to the database then.
- alfred -
Alfred NESWADBA
